Embedded and Microcontrollers
Embedded Forum Constant current source build
  • Subscribers 503 subscribers
  • Views 624 views
  • current_source
  • knode
  • embedded
  • thermal
Latch
Latch over 14 years ago
This should be a walk in the park for most, but I am having a major issue with building a high-precision constant current source.
Right now I am using a LM313 and a JFET in a modified Howland topology. Output needed is 100uA. Problem is, the LM313 is very sensitive to temperature changes and my accuracy is swinging over +/-5%.
Let me change adjectives... I now need and ULTRA-precision current source. Thoughts?
Also, it would be useful if I could just buy a current source circuit and implement it on an existing PCB.
Latch
  • Latch
    0 Latch over 14 years ago
    Is there an off the shelf option?
    Latch
    0 michaelkellett over 14 years ago in reply to Latch
    More spec needed - eg. compliance, bandwidth, accuracy, ground referenced or is resistor between load and ground Ok etc.
    Michael Kellett
    Take a look at the precision current pump application in the OP200 Data sheet.
    try this...temperature compensated current source with 1% accuracy......
    http://www.ti.com/lit/wp/snva579/snva579.pdf
    Also please give more inputs as mentioned by Kellet to make the requirement more clear.......
    EA
