Embedded and Microcontrollers
Embedded Forum NXP LPC23xx using eclipse(Keil Convertion)
  • Subscribers 502 subscribers
  • Views 400 views
akaka
akaka over 13 years ago
Hi all,
I am trying to "convert" a project from Keil  in Eclipse using ggc& gnu arm.
Everything seems ok and I have created the hex file but it does not work.
Has anyone tried to make anything similar?
Regards
Chris
    Keil does support the GNU C compiler.
    http://www.keil.com/arm/gnu.asp
    According to my sources, " The MDK debugger works with and can read in ELF files just fine. The developer would need to make sure they are including debug information in the image in order to do full debug. The HEX file wouldn’t include any of that information."
    You may also want to look at this application note.
    http://www.keil.com/appnotes/docs/apnt_199.asp
