Embedded and Microcontrollers
Embedded Forum STM32F4Discovery ( IDE, compiler, toolchain...)
  • Answers 2 answers
  • Subscribers 502 subscribers
  • Views 1022 views
  • stm32f4
  • stm32f407
  • embedded
  • st
  • stm32f4discovery
gihu
gihu over 13 years ago
Hi all,
I want to set up an envoirement for programming a STM32F4Discovery, I have tryed out Eclipse + Yagarto toolchain, and Coocox, but I am not really still convinced.
Today I will to do the same with the free versions of IAR and Attolic, but....
Can anyone tell me about thier preferences and experience with these (or any other) envoirements for the stm32f4?
I hope it can also helps to many other people.
Thanks in advance,
Miguel
    e14 Contributor over 12 years ago +1
    You could try Em::Blocks. It's working out-of-the-box with the discovery boards. http://www.emblocks.org It has by far the best native debugger for GDB. The newest release also supports semihost and live…
  • vsluiter
    0 vsluiter over 13 years ago
    Hi gihu,
    No direct experience with STM32F4 yet, but you could try this guide I wrote for STM32F0: http://www.hackvandedam.nl/blog/?p=707
    http://www.hackvandedam.nl/blog/?p=707In general, you'll have to do the same: set up the libraries and search paths, and find the linker file and startup script. Finding out the debugging commands can sometimes be a bit tricky, but this has worked for me for STM32F0 and STM32F3. With a bit of work I also got a reliable toolchain going for EnergyMicro (with Segger J-Link).
    In short, my toolchain works with GCC (arm-none-eabi), Code::Blocks IDE and openocd for debugging. Very happy with it, using it both on Linux and Windows.
    You may find this interesting.
    Setting up the STM32F4 with Keil µVision
    http://eliaselectronics.com/stm32f4-tutorials/setting-up-the-stm32f4-with-keil-%C2%B5vision/
  • gihu
    0 gihu over 13 years ago in reply to vsluiter
    I have emIDE, that is base on Code::Blocks IDE, so maybe I will try to configure with your guide. By now, I will go on with CoIDE.
    Thank you very much image
  • gihu
    0 gihu over 13 years ago in reply to e14 Contributor
    One not much constructive comment on that page, but many other interesting article in the block for the f4Discovery.
    Thank you very much!! image
    The newest release also supports semihost and live data updates.
    Regards
