Embedded and Microcontrollers
Embedded Forum Is there any good free AVR compiler other than Codevision AVR ???
  • Answers 2 answers
  • Subscribers 504 subscribers
  • Views 2469 views
  • avr
  • compiler
  • free
saurocksall
saurocksall over 12 years ago
i wanted to know if there are any free avr compilers without code size limitations ??? i am a student and i don't have money to buy the full version of CodeVisionAVR and i don't want to download cracked version from any torrent... the free version restricts the code size ..
  • johnbeetem
    johnbeetem over 12 years ago +1 suggested
    I haven't done any AVR programming in over a decade so I don't have specific recommendations, but I'm reasonably sure that there are GCC-based free tools out there. If nobody gives direct pointers, I'd…
    e14 Contributor over 12 years ago +1
    Hallo, i expect gcc (avr-gcc) is what you lokking for. There are a lot of possibilities to use it.You can use Atmel studio a visual sutdio based ide (probably what you are locking for, as previous user…
  • mc_vio
    mc_vio over 12 years ago +1
    For linux : apt-get install gcc-avr binutils-avr gdb-avr avr-libc avrdude For Windwos : Winavr with AvrStudio And working with CodeBlocks .. also in Windows and linux I suggest you linux because you are…
  • johnbeetem
    0 johnbeetem over 12 years ago
    I haven't done any AVR programming in over a decade so I don't have specific recommendations, but I'm reasonably sure that there are GCC-based free tools out there.  If nobody gives direct pointers, I'd start with Wikipedia's Atmel AVR page and follow the links.
    Edit: Interesting -- In some contexts, if you "show less", the link turns into normal text, whereas "show more" brings the link back.  My HTML must be right on the threshold.
    Hallo,
    i expect gcc (avr-gcc) is what you lokking for. There are a lot of possibilities to use it.You can use Atmel studio a visual sutdio based ide (probably what you are locking for, as previous user of codvision avr). Os you use gcc direct using WinAvr or avr-gcc (which is available on most linux distrebutions).  I currently use a setup on linux based on Eclipse, cmake, avr-gcc, avrdude which is complex but powerful.
  • mc_vio
    0 mc_vio over 12 years ago
    I suggest you linux because you are moving to NXP cortexM0 or ARM quickly
    you can find avrstudio 5 and 6 in atmel site for both 8-16 and 32 micro controllers
    and sure you can use avrsudio4.18 for as a start point of programing
    you should as well have winavr installed on your pc
    ps:avrfeaks and atmel site are good sources to find things about mega and xmega controllers
