Embedded and Microcontrollers
Embedded Forum Regarding Project
  • Subscribers 503 subscribers
  • Views 487 views
Regarding Project
Hello good morning,
               Im Harpreet singh i doing my project in embedded system area. Here im using raspberry Pi to interface my devices. I finding difficulty to interface GPS module with RPi. I hope i ll get a good response from you.
  • gadget.iom
    0 gadget.iom over 12 years ago
    About the only thing people have to go on here is that you're using a Raspberry Pi. A little more detail might the helpful.
    Have you tried a GPS with USB interface?
    PH8 GPS USB TERMINAL - MC TECHNOLOGIES - MOD, UMTS / HSDPA GPS USB TERMINAL | Newark element14 US
    OR adapting other GPS cards?
    http://learn.adafruit.com/adafruit-ultimate-gps-logger-shield/overview
    EMBEDDED PI - EMBEST - STM32 I/O BRIDGE, RASPBERRY PI, ARDUINO, 32BIT ARM | Newark element14 US
    All of the standalone GPS modules I've seen use a serial interface. I would use a wireless console, and use a serial port to interface with the GPS. There are libraries that support the protocols that the GPS modules speak, such as NMEA. It is fairly simple to parse, you can easily do it yourself. Some modules have faster serial protocols that require a bit more footwork, but they will default to NMEA if you set them properly.
    You can have problems if the GPS is at a different level than the card, so you might need some sort of level shifter.
    There are many projects online that do this sort of thing. Just search around. Here is one:
    Getting GPS to work on a Raspberry PI | Peter Mount's Blog
    I can't vouch for it, I just searched and found it.
