Embedded and Microcontrollers
Embedded Forum how do i access RAM on a USB flash drive ?
  • Answers 2 answers
  • Subscribers 503 subscribers
  • Views 1938 views
  • drive
  • usb
  • flash
TaylorTronics
TaylorTronics over 12 years ago
hello smart people, nerds, wiz-kids and enthusiasts image
i need the protocol to access memory on a USB stick image
i know that i send address, data and control information to access a location in flash ram, but what is the format image
address first (LSB to MSB), data second, then a read or write control byte third image
i noticed that as something becomes worth more on the market, it becomes harder to get concise and comprehensive technical data image
the PIC18F4455 microcontroller has a 430 page data sheet. usefull for actually designing operational circuits image
3 pages for a USB stick? useless if i want to hook it to my PIC development board image
the USB protocol aint a problem. theres tons of data on that image
all answers welcome image
peter image
image when in doubt, ask image
  • johnbeetem
    johnbeetem over 12 years ago +2 verified
    I've never played with a USB Flash Drive at the USB protocol level, but my understanding is that a USB Flash Drive is handled as a USB Mass Storage device, with the actual access to the memory chip handled…
  • TaylorTronics
    TaylorTronics over 12 years ago +1 suggested
    thanks john i have found that usb ram is accessed using the usb mass memory protocol simple realy, untill you read it i found the answer at edaboard.com in microcontrollers, with 255,000 views definatly…
  • johnbeetem
    0 johnbeetem over 12 years ago
    I've never played with a USB Flash Drive at the USB protocol level, but my understanding is that a USB Flash Drive is handled as a USB Mass Storage device, with the actual access to the memory chip handled through a microcontroller in the Flash Drive.  The uC takes care of things like wear leveling so that the flash memory writes are distributed across the chip instead of wearing out one region.
    For general information on USB Flash Drives, try Wikipedia: http://en.wikipedia.org/wiki/USB_Flash_drive
    For specific information on USB device protocols, try USB.org: http://www.usb.org/developers/docs/devclass_docs/
  • TaylorTronics
    0 TaylorTronics over 12 years ago
    thanks john image
    i have found that usb ram is accessed using the usb mass memory protocol image
    simple realy, untill you read it image
    i found the answer at edaboard.com image
    in microcontrollers, with 255,000 views image
    definatly go thier for an answer, in fact 5 answers image
    you are on the nail image
    peter taylor image
    image  the sun does revolve around the earth image
  • vmate
    0 vmate over 5 years ago
    I'd use an SD card instead, they support SPI for communication, so they are much easier to interface with. Also, the microcontroller you mentioned only supports USB device as far as I can tell, and you'd need USB host capabilities. You can bit bang it, but that's even harder, and really slow.
