Embedded and Microcontrollers
Embedded Forum TM4C1294 Connected LaunchPad + Linux/Ubuntu ???
  • Subscribers 503 subscribers
  • Views 502 views
  • mspgcc
  • ccstudio
  • Ubuntu
  • connected
  • launchpad
  • ti
  • linux
vish
vish over 12 years ago
I'm planning to use TM4C1294 Connected LaunchPad. But I would like to know some more details about the dev environment under Linux/Ubuntu before getting it in hands.
Currently I'm using MSP430G2 launchpad with my Ubuntu system with Energia and MSPGCC. I'm aware that CCS doesn't have support for this kit in Ubuntu.
Now I want to try the connected launchpad. I have the following queries :
1. Does CCS has support for TM4C1294 Connected LaunchPad in Ubuntu( 14.04 )?
2. If not, what are the alternatives available? I saw the option for Connected lanchpad in Energia. But is there any other compiler suite/toolchain available for Ubuntu? I wish to have proper debugging facility too.
Any links for setting up those toolchains will be appreciated.
Thanks ahead,
vish
    You may find this interesting.
    Tiva C Series TM4C1294 LaunchPad - Texas Instruments Wiki
    TivaTm C Series Development and Evaluation Kits for KeilTm RealViewRegistered MDK
    http://www.ti.com/lit/ml/spmu355/spmu355.pdf
    MDK-ARM Microcontroller Development Kit
    Keil MDK-ARM
    ARM DEV KIT, KEIL MDK, STD, NL, CORTEX M
  • vish
    0 vish over 12 years ago in reply to e14 Contributor
    But all the above links talks about toolchain for Windows. I need a toolchain for Linux/Ubuntu.
    0 e14 Contributor over 12 years ago in reply to vish
    USING MDK-ARM ON LINUX
    ARM Information Center
    A native Linux version is not available. You can run MDK-ARM under WINE with certain limitations.
    The following has been tested with:
    • MDK-ARM 4.20
    • Ubuntu 10.10
    • Wine 1.2 (installed from Ubuntu Software Center).
