Embedded and Microcontrollers
Embedded Forum Silicon Serial Number ic
  • Replies 9 replies
  • Subscribers 502 subscribers
  • Views 1274 views
Has someone a good suggestion of a silicon serial number ic with the least bits configurable?
I need for my design a unique serial number but one of the least bits should be set by a dip-switches to indicate their physical location.
    0 michaelkellett over 12 years ago
    Are you at the stage where you can choose the processor - some of the latest ST ARM Cortex parts have a built in unique ID.
    Failing that there are Dallas (now owned by Maxim) 1 wire eeproms with a unique ID and eeprom built in.
    MAXIM INTEGRATED PRODUCTS - DS2431+ - IC, EEPROM, 1KB, 1-WIRE, TO-923
    MAXIM INTEGRATED PRODUCTSDS2431+
    Image is for illustrative purposes only.
    Please refer to product description
    Manufacturer:
    Order Code:
    1606350
    Manufacturer Part No:
    DS2431+
    Technical Data Sheet (368.68KB) EN
    5 Silicon Serial Number IC products found
    http://uk.farnell.com/special-function/ic-function/silicon-serial-number-ic/pg/110197076
    0 michaelkellett over 12 years ago in reply to e14 Contributor
    None of these parts (the Silicon Serial Number chips) offer any means for setting bits to a user pattern and the eeprom part doesn't really do what the OP wanted.
    You could use a tiny micro like this with a unique ID built in:
    NXP - LPC811M001JDH16FP - MCU, 32BIT, CORTEX-M0+, 30MHZ, TSSOP-16
    NXPLPC811M001JDH16FP
    Manufacturer:
    NXP
    Order Code:
    2320693
    LPC811M001JDH16FP
    Technical Data Sheet (560.89KB) EN
    But you would need to programme each one - it would have no trouble reading DIL switch and maybe doing something else as well. Cheaper than the Maxim parts too.
    0 e14 Contributor over 12 years ago in reply to michaelkellett
    Thanks for your efforts to help me, I will consider the options!
    No bother - if you go the tiny processor route please let us know because it's rather interesting that it might make economic sense to use a 32 bit micro for such a mundane purpose.
    perhaps an ATtiny or a PIC12Fnnnn would be just as good and even cheaper.  Definately agree that it's getting interesting when it actually makes sense to use a micro for stuff like this. I expect it'll become more common in the future too.
    Do the ATtiny or the PIC have their own unique ID burnt in during manufacture ?
    probably not, but given you'll have to program your code in anyway, it may not be an issue, you can usually code protect these things to some degree for a bit more security if necessary
    unique ID is a strange area, I've come across an I2C RTC chip that has a factory programmed EUI-64, so there are ways to get that done cheaply.   It's the need to change some part of the returned ID via dip switches that gets you thinking about micros.
    What about one or more 74HC165 shift registers ?  Configure some of the parallel inputs with resistors and some via dip switches?  Sure, it's horrible to manufacture a unique ID by resistor placement, but then Tom didn't say if he's building 2, 10, 100k or many millions. The simple approach could work if he's only building a handful.
    Sometimes you take component features for matter of course but after a while you realize that specific feature of ic is not existing.
    I forward this to our project group and they consider that family identification was more important than unit-unique-ID.
    So at this time, we skip the unit-unique-id and only use a dip-switch family settable ID and for that task I probably use a I2C I/O expander IC connected to the dip-switch.
