Embedded and Microcontrollers
Embedded Forum LPC4357
  • Subscribers 503 subscribers
  • Views 314 views
  • lcd
  • embedded
  • display
  • lpc4357
LPC4357
I am using lpc4357-evb and downloaded example files from element14.  When used the file for LCD demo, it works fine with a 4.3" display, but when I use the same demo file in a 7" TFT display, am not getting any image displayed, but some blurred lines all over the screen, what would be the problem.  Also, I am only able to use InFlash not SPIFlash, getting programming algorithm not found,  can anyone have solution?
  • jobmenue
    0 jobmenue over 10 years ago
    Which compiler do you use to compile your code? I can't get the example code to work...
