Embedded and Microcontrollers
Embedded Forum Package For Diode Bridge
  • Subscribers 503 subscribers
  • Views 293 views
piranha
piranha over 11 years ago
What packages do you all use for Diode Bridge Rectifiers for surface mount. I'm curious because there are not packages that I would expect to see for single diode bridge rectifiers. I see their are many options for 4-SMD packages, I do not see any single diode bridge rectifier SOIC packages(Why is this)? I find on Digi-key that 4-SMD packages max out at 2A for current, I would like higher current available, so thats why I'm asking what SMT package do you use or recommend for SMT?
  • johnbeetem
    0 johnbeetem over 11 years ago
    I like SOT-23 or similar package with two diodes in series.  You can use two of these to make a bridge.  You get more layout flexibility than four diodes in a package.  You can use the same part for voltage-clamping inputs elsewhere in the design, and use the part as a single diode by leaving one of the pins unconnected.  This way you can use a single part multiple times, simplifying your BOM.
    Here's a typical ON Semi part: http://www.onsemi.com/PowerSolutions/product.do?id=BAS40-04L
