Embedded and Microcontrollers
Embedded Forum Linux distribution login password lost
  • Answers 2 answers
  • Subscribers 502 subscribers
  • Views 701 views
  • password
  • sama5d3
  • atmel
  • linux
  • xplained
newto10
newto10 over 11 years ago
Few months back i started working on Atmel Board SAMA5D3 Xplained board. It has a built in Linux distribution(Yocto/poky Distribution) and initially gave access as a root user without asking for a password. Now since it has been a while since i have worked with this board and unfortunately lost the login password which i had set few months before. Now like every linux distribution it does not have GRUB startup just after it boots so i cannot change the password. I am looking for any other option now since I access the board with serial emulator Tera Term on Windows OS. Is there a solution for this problem??
    Maybe you should try to follow this community member's approach to get Debian running from SD card. It is also a nice learning traject ;)
    http://www.element14.com/community/community/designcenter/sama5d3xplained/blog/2014/04/25/debian-on-the-sama5d3-xplained
  • clem57
    0 clem57 over 11 years ago
    I can tell you need to get to UBOOT. See U-Boot < Linux4SAM < TWiki. Under that you can set runlevel 1 where you can use the passwd command to set a new password.
    Clem
    0 e14 Contributor over 11 years ago in reply to clem57
    Indeed lets make life easier for Monish image
    Qemu can be handy to simulate and assist qemu: roms/u-boot/arch/arm/cpu/arm926ejs/at91 Directory Reference - doxygen documentation | Fossies Dox
    Long time ago I used that great tool by Fabrice Bellard image
    If Monish can get at the prompt to enter U-Boot and hit a key then something like
    U-boot> setenv bootargs ${bootargs} 1
    U-boot> saveenv
    U-boot> boot
    Should enable him to change passwd I guess.
