Embedded and Microcontrollers
Embedded Forum CMSIS-RTOS
  • Replies 19 replies
  • Subscribers 500 subscribers
  • Views 8328 views
  • rtos
CMSIS-RTOS
msimon
msimon over 4 years ago
Hi everyone,
I want to dive into RTOS for microcontrollers. I decided to use FreeRTOS then I came across CMSIS-RTOS. If I get it correct it is a wrapper for RTOSs so you can change underlying RTOS without chancing your code.  I wonder are there any real benefits of using CMSIS-RTOS rather than using native RTOS like FreeRTOS interface?
Thanks.
    Jan Cumps over 4 years ago in reply to msimon +4
    Self promotion :) : balearicdynamics and I made a project last year , with FreeRTOS, that uses most of the principles there: scheduler and task semaphore/mutex message queue events and inter…
  • phoenixcomm
    phoenixcomm over 4 years ago +3
    FreeRTOS is very capable. why do you want to wrap it? In larger RealTime projects we do two things in this order 1. launch the OS like Debian. 2 now launch the task scheduler which is interrupt-driven…
    Jan Cumps over 4 years ago in reply to BigG +3
    MBED OS and CMSIS-RTOS are changing so fast that I can't follow anymore what they are, what they wrap and what they are based upon I know TI-RTOS and FreeRTOS fairly well. Although they are completely…
  • BigG
    0 BigG over 4 years ago in reply to msimon
    Normally I don't pay much attention to emailed newsletters but this one caught my eye as the latest from ST mentions Azure RTOS with STM32F7.
    www.st.com/.../x-cube-azrtos-f7.html
    0 Jan Cumps over 4 years ago in reply to msimon
    Self promotion :) : balearicdynamics and I made a project last year, with FreeRTOS, that uses most of the principles there:
    • scheduler and task
    • semaphore/mutex
    • message queue
    • events and inter-task messages
    • tasks going to sleep
    • interrupt
    additional:
    • controller going to low power
    • controller wakes up via HW interrupt when data arrives on UART and kicks off a message.
    • wifi
    • AWS IoT / MQTT
  • msimon
    0 msimon over 4 years ago in reply to BigG
    It is interesting. I am biased against Microsoft products but this one looks OK. It also supports certifications. However, "X-CUBE-AZRTOS-F7 is only an STM32Cube integration of middleware stacks from Microsoft® Azure® RTOS." It is a bit confusing, I need to look for Azure RTOS in detail.
  • msimon
    0 msimon over 4 years ago in reply to Jan Cumps
    Thanks Jan Cumps. It looks like a good example of RTOS project. I will also investigate low power RTOS design but I have a long way to go before I dive into it.
    This part is most of the time vendor dependent.
    What is independent: telling FreeRTOS what sleep modes are allowed. FreeRTOS knows when a next job is due and will know how to wake up.
    What is dependent: how you work with HW drivers in low power and wake up FreeRTOS when a HW event happens. Like most of the HW/driver logic, this is not abstracted by the RTOS.
    It's FreeRTOS. My example above uses it.
  • msimon
    Sorry, it was reply to BigG's comment but it sit under yours. I have also read you made hello world project with FreeRTOS, blinking an led :)
  • david.long
    0 david.long over 4 years ago in reply to Jan Cumps
    No, Azure RTOS is Threadx - previously a commercial RTOS from Express Logic.
    It has many similarities to FreeRTOS.
    0 Jan Cumps over 4 years ago in reply to david.long
    You are right. I was mixing with Amazon's RTOS. That's the one I'm using in my example.
