Embedded and Microcontrollers
Embedded Forum can anyone explain to me in detail how can i send data between to mcus?
  • Subscribers 503 subscribers
  • Views 855 views
  • silicon_labs
  • efm32™
  • beaglebone-black
iam trying to send data between silicon labs efm32 dev kit and beagle board
    shabaz over 10 years ago in reply to e14 Contributor +2
    Hi Sushanth, It is up to you to select an interface. johnbeetem has provided some popular examples. Once you have decided on an interface, you can google for code examples for that interface and for your…
  • johnbeetem
    johnbeetem over 10 years ago +2
    Here's an excellent 'blog and comments at Geek Times that compares various ways to interconnect processors: Linking 2 MCUs: I2C, SPI, or a Home Grown Interface? As shabaz says, first understand the capabilities…
  • johnbeetem
    johnbeetem over 10 years ago +1
    I don't have time to go into details, but usually the best way to send data between MCUs is via their UART or SPI interfaces. UART is usually easier. SPI is usually faster. Take a look at the UART and…
  • johnbeetem
    Take a look at the UART and SPI pins for your MCUs and what software is available.
    e14 Contributor over 10 years ago in reply to johnbeetem
    I have a beagle board and silicon labs efm32. i want to send data iam receiving from efm 32 to my bbb and display it on my computer. iam not able to figure out how to code bb to make efm32 to send data to it.
    Thank you,
    sushanth.
    Hi Sushanth,
    Once you have decided on an interface, you can google for code examples for that interface and for your desired programming language.
    Because these interfaces are standard, you can be assured that your two boards will communicate. As a result, you don't need to search for
    a "beagle board to EFM32" solution. You just need to search for "beagle board X interface" example software, and "EFM32 X interface" example
    code where X is the interface you have chosen.
    If you're unfamiliar with the interfaces mentioned, then you really need to read up on them (wikipedia at a minimum) because they are fundamental for device interfacing.
  • johnbeetem
    As shabaz says, first understand the capabilities of the various interfaces available on both of your boards (I also find Wikipedia to be a good starting point) and then look for examples of using those interfaces on each of your processors.
