Embedded and Microcontrollers
Embedded Forum Microcontroller Bargains
  • Replies 23 replies
  • Subscribers 503 subscribers
  • Views 7036 views
  • msp430g
  • msp430
shabaz
shabaz over 4 years ago
If anyone is on the hunt for affordable microcontrollers in stock : ) Despite the component shortages, there's some extremely low-priced microcontrollers still available, if one is not so choosy on package style.
For instance, MSP430G2212 parts are just 59 pence currently. It's only got 2kbyte Flash memory and 256 bytes of RAM, but that's still useful for a lot of things. The development environment, CCS, is stable, and coding for it is quite nice (although as mentioned, the amount of Flash and RAM could be an issue depending on what you want to do with it). The DIP package is large, but not all circuits require being compact.
To program it, one very cheap option is to purchase a MSP-EXP430G2ET Launchpad board, and use that to program the chip, however that's out of stock. The board has a 20-pin DIP socket so it’s easy to plug in the chip, program it, and then insert the chip intoyour circuit.
Another option is to buy an MSP430 programmer. The programmer needs to support 2-wire JTAG, also known as Spy-Bi-Wire or SBW, or 4-wire JTAG. A ‘BSL’ programmer is often cheaper but won’t work for this chip. A suitable programmer is MSP-FET. The older model MSP-FET430UIF will also work, and there are low-cost clones of the MSP-FET430UIF on AliExpress, which claim to support SBW, but I have not tried them.
  • Andrew J
    Andrew J over 4 years ago in reply to shabaz +5
    These little projects you put together are really good learning tutorials. Useful and not too simple, but not at all complex either. Or expensive!
  • Andrew J
    Andrew J over 4 years ago +3
    Ironic that the chip is in stock but the programmer isn’t! Good point to highlight though as it would be very frustrating to design for a part in stock to find you now have to wait a year to program it…
    genebren over 4 years ago in reply to shabaz +2
    Hi Shabaz, There are some of the ATtiny1604, ATtiny1616 and ATtiny816 parts in stock at Newark. Good that you bought the Atmel-ICE as this is required by the new parts. I had an older Atmel-ICE that…
    Nice find!  There are also some of the new ATtiny family parts in stock (mostly the smaller memory size, 8K and some 16K).  This is exciting news as my favorite Atmel/Microchip part, the ATmeag328PB is out of stock, with far out ship dates, and I am running out of stock.  Some of these new ATtiny parts like the ATtiny3226 will work on some of my designs, but they are only trickling into stock.
    shabaz over 4 years ago in reply to genebren
    Hi Gene,
    The ATtiny parts are great! Glad that you're finding stock for your designs. I might at some stage start using ATtiny if they are becoming in-stock, I purchased an Atmel-ICE basic kit at the start of the pandemic, in case I could find suitable parts.
    Hi Shabaz,
    There are some of the ATtiny1604, ATtiny1616 and ATtiny816 parts in stock at Newark.  Good that you bought the Atmel-ICE as this is required by the new parts.  I had an older Atmel-ICE that I bought years ago, but the MicroChip Studio flashed the firmware up to date and everything worked out great.
    I have just started playing with the ATtiny3224 which took a little time to get use to, but it worked out fine.  Unfortunately, I ran out of pins on the ATtiny3224 due to a design change.  I have some ATtiny1606s that I plan to use for a prototype, which I can upgrade to ATtiny3226s when they become available.
  • Andrew J
    Ironic that the chip is in stock but the programmer isn’t!  Good point to highlight though as it would be very frustrating to design for a part in stock to find you now have to wait a year to program it!
    shabaz over 4 years ago in reply to Andrew J
    Just noticed RS has the MSP-EXP430G2ET board in stock (just about - only 17 currently available), it's in some ways better than a dedicated programmer because it has a DIP socket for directly programming the parts, but can also become a proper in-system programmer by running four wires from one of its header connectors. The AliExpress clones of the MSP-FET430UIF dedicated programmer might be ok, but I think it's not worth the risk.
    I've been experimenting with the chip on perfboard as a home-made development board. The header pins at the top are the four wires (3V3, GND, SBWTDIO, SBWTCK) that go to the programmer. I'm powering this board with two AA cells. The board is really ugly construction : ) but is fine for getting to grips with coding for it. I've created an example project, hopefully I'll write it up in the next few days. As expected, the memory was tight, but it was possible to squeeze in quite a few features, and still have a few tens of bytes spare.. For me this PDF document was invaluable to learn how to conserve memory space.
  • Andrew J
    Nice one, bound to come in handy when those 17 have gone.
  • BigG
    BigG over 4 years ago
    often overlooked... EFM8's from Silicon Labs...
    This one has 2kB flash and 256B of RAM and cheaper still...
    https://uk.farnell.com/silicon-labs/efm8bb10f2i-a-qfn20/mcu-8bit-25mhz-qfn-20/dp/3605195
  • BigG
    BigG over 4 years ago in reply to BigG
    25MHz compared to your paltry 16MHz Smile
    shabaz over 4 years ago in reply to BigG
    Good find!
    So far these ones are all a very similar bargain price : ) sub-60-pence, and good availability at least for prototyping:
    MSP430G2212
    EFM8BB10F2I-A-QFN20
    ATtiny414
    The ATtiny has twice the Flash (4kbte instead of 2kbyte), but minimum order of 100 - not insurmountable, so I think it's worth being on the list : )
  • BigG
    BigG over 4 years ago in reply to shabaz
    Here's another Silabs sub-60-pence option:
    Has a pretty good spec too (16kByte Flash, 1280Byte RAM @50MHz):
    EFM8BB51F16G-C-TSSOP20
    BUT... I think I found a winner (if +10 or +100 quantities are used for comparison as well)...
    uk.farnell.com/.../2908849
