Embedded and Microcontrollers
Embedded Forum ARM Keil MDK is free (sort-of)
  • Replies 35 replies
  • Subscribers 502 subscribers
  • Views 21634 views
  • mdkarm
  • keil
  • mdk
shabaz
shabaz over 4 years ago
For ages, the Keil development environment/compiler which they call MDK (Microcontroller Development Kit) has been a chargeable product, extremely unaffordable for home use : (
It's really annoying when microcontroller manufacturers only supply sample code using Keil. It's not always easy to port the project files to Eclipse, often it's hard and a lot of work!
For curiosity I re-logged onto the Keil website today, and noticed there is now a Community Edition! The announcement was in March it seems.
There doesn't seem to be a code limit, which is great.
I just now tried to build some sample code from Dialog Semiconductor (they have cheap BLE chips but 95% of the more useful example projects are with Keil, not Eclipse, hence the interest) and it worked and I was able to download to the target eval board, which has an integrated J-Link, so that works too. I'm still learning how to use Keil, it's new to me.
Keil has a pack system which is quite neat.. I've only installed the Dialog specific pack so far:
Anyway, I just thought I'd mentioned that the community edition was available, in case anyone else is interested in trying it too.
  • scottiebabe
    scottiebabe over 4 years ago +2
    This is great news! That is one of my biggest complaints about the Pico, trying to setup the c development environment is way too complicated for a causal complier user.... I like one button installs,…
  • WestfW
    WestfW over 4 years ago in reply to scottiebabe +2
    > When you use the ardunio framework somewhere there is a trigger to have the rp2040 reset into bootloader mode (I'm not sure how its done) Arduino uses a hack where setting the usb/serial bitrate to…
  • Fred27
    Fred27 over 4 years ago +2
    I've only ever used Keil when exploring the Cortex M0 and M3 soft processors on Xilinx FPGAs. Keil was the only IDE supported and was way to expensive to consider beyond experimenting using the free trial…
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to shabaz
    go to the eclipse store?  and grab the toolchain. fins here is the video on how to.
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to phoenixcomm
    go to the eclipse store?  and grab the toolchain. fins here is the video on how to. I found this on Youtube "Add GNU ARM Plug-ins to Eclipse IDE"
  • phoenixcomm
    eclipse is a very easy IDE to use. Download the one w/ Java in it. fins.  follow the prompts and tell to install C/C++ modules
    then look at the video and install the TOOL CHAIN for ARM v6
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to maxpowerr
    my directory's are as follows
    NexGen
        ADI-ARU-50.A     //one of 26 modules
        RSS
            src
                 Java
                        Main
                        Test
             Radios
                  C-3436A-ARN-30     // one of eight modules
                        Docs
                        src
                                 C-3436
                                         C-3436.ino
                                         C-3436.h
                            Java
    Please don't get me wrong this is a very large project     As well as a Top-level NexGen dir there is also a E-14 with a similar layout this Layout is handy in Eclipse IDE as it uses Mylyn layout but uses Gradle for my builds much nicer than make.
  • WestfW
    WestfW over 4 years ago in reply to phoenixcomm
    I don't see how that solves the Keil vs Gnu compiler/assembler compatibility issues.  Is there an Eclipse or gcc package that explicitly provides Keil compatibility?
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to WestfW
    what compatibility issues are you talking about? basically gcc is the gold standard of C/C++ compilers. and btw West did you bother to look at the post I did about 1hr before your post! (hint the one with the video)
  • WestfW
    I don't know for sure, since Keil has always been too expensive for me, or eliminated for other reasons.  @shabaz says they have vendor-provided example Keil projects that won't build with Eclipse/gcc, and I see no reason not to believe them.
    There are a couple of obvious incompatibilities:
    • The Keil assembler implements the ARM-defined assembly language, while gas take liberties in the name of commonality over a wide range of CPU architectures.
    • The Keil linker uses "scatter/gather" config files where gcc uses "linker scripts."
    • Presumably the meta-data describing a "project" is substantially different between MDK and Eclipse.  My projects have always been either small enough that I'm happy with an editor and a Makefile, or big enough that there is a "tools team" that handles the complicated part.
    And a bunch of things to worry about:
    • pragmas, attributes, and intrinsics (hopefully CMSIS mitigates the intrinsics issue.)
    • some sort of "pack" support to drag in the chip-specific definitions.  Keil supports a lot of chips; I'm not sure about eclipse.  And manually installing vendor .h files can be a pain.
    • embedded ARM gcc environments tend to use newlib or newlib-nano, Keil has their own libc implementation. (and something similar for C++)
    • Keil has a bunch of middleware libraries with license issues in a gcc environment.  If the code you're trying to port uses them, all the language-level compatibility in the world won't be very helpful.
    Dealing with this is all "bread and butter" for an "embedded SW engineer", but is surely really annoying if all you want to do is try out a vendor's example code.
    (and yes, I saw your post with the video.  Which afaict is about installing arm-gcc, nothing Keil-specific.  That's what prompted my comment.)
  • WestfW
    WestfW over 4 years ago in reply to shabaz
    Wait - have you actually managed to install Keil support for RPi Pico?  I don't see even the rp2040 in their "packs", and I'd think that configuring Keil to use the SDK would be a significant effort!
    (or is this just a "side discussion"?)
  • WestfW
    Arduino uses a hack where setting the usb/serial bitrate to 1200bps causes a chip reset (and enter bootloader.)
    Entering the bootloader via application SW command is easy - there's an SDK/ROM function for that: reset_usb_boot()
    shabaz over 4 years ago in reply to WestfW
    I didn't see the comments, the e-mail notifications seem to have stopped : (
    It's exactly that, it's the incompatible project build stuff, and nothing to do with installing GNU tools, I can install those.
    phoenixcomm it's the porting of project build settings, which would need someone to go into Keil and Eclipse, to translate from the Keil format (it uses it's own proprietary configuration files). I could do that, but it could take weeks of effort for someone like me who doesn't know Keil to learn it enough to translate those files - I can only manage with traditional Makefiles.
    Also the assembler stuff for sure would get awkward, because there will be differences in file formats for .asm files between Keil and GNU ARM, so if any assembler source is present then that needs converting, plus many assembler directives will look different between Keil and GNU. The linker settings like particular RAM and Flash regions will be specified differently too, so that needs translation as well. This is all work I'd rather not do if it's not a paid-job task.
    The projects in question are in a separate Blog post Easy, Cost-Effective Bluetooth LE (BLE) with Dialog DA14531MOD  which was the motivation for using Keil, because 95% of the manufacturer examples for that chip/module use Keil.
