Embedded and Microcontrollers
Embedded Forum Companies that design PCB for honest prices?
  • Replies 16 replies
  • Subscribers 505 subscribers
  • Views 2299 views
Greetings,
I am looking for a company that is able to design a PCB, that I can send to a PCB manifacturer, starting from components.
My availability is not that much, I just started to look into the possibility to make the first batch of PCB, probably 50 or 100, but before I need someone that actually make the PCB design.
I found some that does PCB production, but not that much info about who is offering a design service; any suggestion? I would like to avoid unsafe sources; it is not nice to figure out that the design was done wrong; once you spent thousands for PCB production and components.
Thanks!
Luke
    e14 Contributor over 10 years ago +1
    I would suggest designing the PCB yourself, especially since your design doesn't seem particularly complex. To find a board house that will design your board (the way you want it), mill it, and populate…
  • gadget.iom
    gadget.iom over 10 years ago
    I personally prefer to use companies that are as local as possible.
    This can be especially useful throughout the development/prototyping phase.
  • peterjcs23
    peterjcs23 over 10 years ago
    Buy a copy of EAGLE and a couple of books and do the layout yourself.
    http://uk.farnell.com/cadsoft/lsr-1ss/eagle-pcb-make-personal-lsr-1usr/dp/2491320
    https://www.elektor.com/eagle-v6-getting-started-guide
    https://www.elektor.com/books/the-eagle-companion
  • michaelwylie
    michaelwylie over 10 years ago
    EDIT:
    Sorry I misread the title. The service I referenced if for having a PCB fabricated.
    Seeed Studio's Fusion PCB service:
    Fusion PCB, customize PCB prototype | Seeedstudio
    e14 Contributor over 10 years ago in reply to peterjcs23
    That is not an option, sadly.
    I write software; the time that it would take me to learn how to design PCB with Eaglecad, and the subsequent mistakes due lack of experience, would cost me more than hiring someone that knows how to do it.
    I am good at wiring up boards; and I don't think that learning design is something that I can pick in few weeks.
    e14 Contributor over 10 years ago in reply to michaelwylie
    No problem Michael; Once I have the PCB designed I need to eventually go for a manifacturer image
    BTW I do not have a file to upload; I am in the phase were I have the wired prototype; so I actually need someone that design the PCB itself; so I am not sure if seedstudio is the place to go for this. I see that you need to upload a file.
  • michaelwylie
    michaelwylie over 10 years ago in reply to e14 Contributor
    You're exactly right, they want gerber files. Gerber files define the board.
  • peterjcs23
    peterjcs23 over 10 years ago in reply to e14 Contributor
    sounds like the most important thing will be to find someone local, where are you based?
    I am in the San Francisco area; I did a preliminary search but found nothing for makers, as far as design from scratch.
    Most of what I found were more on the industrial side of things; and I am just a regular guy working in his garage image
    Which from a quick search, seems to require a PCB design, and this is exactly what I need help with image
  • michaelwylie
    How complicated is the design? Digital and analog?
