Embedded and Microcontrollers
Embedded Forum BBB host USB port communication issue with USB-RS232 converter
  • Subscribers 503 subscribers
  • Views 444 views
  • bbb hot usb issue.
ramanc51
ramanc51 over 10 years ago
Hi all
         I am using USB-RS232 converter on BBB host USB port, it is working fine, after few minutes it disconnected automatically, then i need to open port(ttyUSB0) to send/receive data again,
Note: few more USB device like keyboard, mouse and another USB-RS422 converted connected on same USB port through usb-hub. What may be the issue on this host USB port , is it related to software or hardware?, if it is related to software, what is the right solution/image version, if it related to hardware or power issue, which component i need to replace?.
    dougw over 10 years ago +1
    Perhaps the power load on the USB power is too high. You could try running all USB devices from a powered USB hub.
  • ramanc51
    ramanc51 over 9 years ago in reply to dougw +1
    Thanks Douglas, i will confirm it after i verify this with powered USB hub.
  • ramanc51
