Embedded and Microcontrollers
Embedded Forum Do not working ethernet with kinetis K64 with KSZ8081RNACA
  • Subscribers 503 subscribers
  • Views 302 views
  • hardware
  • ethernet
  • kinetis k64
  • kinetis
  • frdm-k64f
  • ksz8081rnaca
  • frdm-k64
  • kinetis k
  • hardware ethernet
zavovi
zavovi over 9 years ago
Hi everyone,
I have working software on FRDM Kinetis K64 and I tried make own hardware - I inspired from FRDM K64 schematic. Now, I have issue with connection ethernet. Schematic is on attachment.
I tried read registers from KSZ8081RNACA - it is OK. When I connected cable, then it is not see any change. Any change on registers, any change on router.
Please, could you help me, how can I debug it and find issue? Any idea?
Thank you
Vilem
image04_ethernet.pdf
  • juanguito
    juanguito over 9 years ago
    Hello
    I think I have the same problem that you describe.
    Make my own hardware to work with K64. My problem is that it does not connect the ethernet port after a hardware disconnection (power off).
    Is there any way to power the K64 to keep a transient current at reset?
    Greetings.
    Juan
