Embedded and Microcontrollers
Embedded Forum Is this a good idea for solar tracking system?
  • Subscribers 502 subscribers
  • Views 440 views
imohannad
imohannad over 9 years ago
I'm trying to make a project for a contest in my country which is limited by the cost and should be innovating.
And because we ran out of ideas I thought to make a solar tracker system with a little adjusment.
My idea is to make the same independent of sensor lights and continuous movement , but to make it update the module inclination every day / week(saving power) using the actual location of the module on the earth. i.e the user has to provide the module with the longitude and latitude and the module will do the rest.
What i want to know is ...  Is that a good idea? or .. is that even an idea? image
Sorry for bad english, it's not my native language.
  • clem57
    clem57 over 9 years ago +4
    Sounds like a start. Firstly see https://en.wikipedia.org/wiki/Innovation o understand what you are trying to do. Next browse other people innovative ideas and see any room for improving them, I saw this…
    shabaz over 9 years ago +3
    Also dougw project is worth checking, it uses methods that may meet some of your needs too: Make Life Accessible - Clear Walk - Introduction - blog 1
  • clem57
    Sounds like a start. Firstly see https://en.wikipedia.org/wiki/Innovation o understand what you are trying to do. Next browse other people innovative ideas and see any room for improving them, I saw this as a sample (not to be used verbatim) 4 Innovative Solar Tech Projects From Around the World . I am sure you can look around you and get some great ideas. Key point:  check out if it has been done already on the internet. If not you may have hit a gold mine. Good luck and post your project here.
    Clem
