Embedded and Microcontrollers
Embedded Forum interferential current therapy machine using 89s52
  • Subscribers 503 subscribers
  • Views 504 views
meenakshisaini
meenakshisaini over 8 years ago
hello everyone
I have just started to do work on interferential current therapy machine .  Is anybody have any idea or some previous work on it please share.
Thank you .
    michaelkellett over 8 years ago +1
    If you are starting on a new design you might want to consider using a more modern processor. The 89S52 is not suitable for generating the kind of signals produced by modern ict machines. Do you have a…
    michaelkellett over 8 years ago in reply to meenusaini +1
    To get sensible advice you would need to explain the project in much more detail. For example: Will you make 1 machine for your own use or many for sale. Do you just want to copy what is already available…
    Do you have  a target specification for the completed machine ?
  • meenusaini
    meenusaini over 8 years ago in reply to michaelkellett
    Thank you for responding. can you suggest any suitable controller for the same.
    For example:
    Do you just want to copy what is already available or will you add your own research or ideas.
    etc, etc.
    The more detail you provide about yourself, the project and the resources/experience available, the better the advice you will get.
