Embedded and Microcontrollers
Embedded Forum Indoor Wireless Temperature Sensor Network
  • Subscribers 503 subscribers
  • Views 493 views
  • ble + 15.4
  • ble/802.15.4
  • sensor data
  • wireless module
lukegar56
lukegar56 over 8 years ago
If I  try to create an Indoor Temperature management at same time system with temperature sensor https://store.ncd.io/product/hih7130-humidity-and-temperature-sensor-%C2%B13-rh-%C2%B11-0c-i2c-mini-module/  using wireless sensor networks which wirelessly communicate with the BLE module, further send all the data to android phone via Bluetooth wireless communication. I need to know the best example in which I can communicate and share the data of 2 different sensors (connected via I2C connection) connected with ESP32 Module and share the data on the android application? Any leads on this will very helpful.
  • oksbwn
    oksbwn over 8 years ago +1
    As you are using ESP32, why don't you use Wi-Fi. That way you can make it IoT enabled. By the way for BLE please check this Android documentation to develop your Android App.
  • oksbwn
