Embedded and Microcontrollers
Pic Microcontrollers Forum TCP/IP Microchip -  SNTP and GenericTCPClient problem
  • Subscribers 235 subscribers
  • Views 294 views
Hello
I've tried the GenericTCPClient exemple: when i push the button on the dev board, i can see on the RS232 the microchip's web html code.
Ok,
Now i want add the SNTP function, so
- when i enable the line : #define STACK_USE_SNTP_CLIENT      in TCPIPConfig.h
i've a pb, the GenericTCPClient exemple seems to be freezed, on the RS232 only the message :
Connecting using Microchip TCP API...
and nothing more.
I've tried to enable the lines:
#define STACK_USE_TCP
#define STACK_USE_UDP
Same behavior,
How to do to enable SNTP and GenericTCPClient?
Thx,
  • MicrochipRTCfr
    MicrochipRTCfr over 15 years ago
    Which TCPIP library version do you use ?
    Did you download the  latest libraries : http://www.microchip.com/MAL ?
    There are 2 possibilities to make projects : use an existing project and modify it or start with the TCPIP stack PC configurator ( TCPIPconfig.exe ).
    Which way did you go ?
    Regards
