Embedded and Microcontrollers
Pic Microcontrollers Forum Need some help with PIC programing [solved]
  • Subscribers 236 subscribers
  • Views 1167 views
  • microcontrollers
  • pic16f690
  • pic
hi, I am using a PIC16f690. i trying to make a LED on RC0 flash with the help of timers. The problem is that the LED is constantly on. using MPLAB X IDE v2.20 and xc8.
#include<PIC16f690.h>
#pragma config FOSC = INTRCCLK  // Oscillator Selection bits (INTOSC oscillator: CLKOUT function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON       // MCLR Pin Function Select bit (MCLR pin function is MCLR)
#pragma config CP = OFF         // Code Protection bit (Program memory code protection is disabled)
#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
#pragma config BOREN = ON       // Brown-out Reset Selection bits (BOR enabled)
#pragma config IESO = ON        // Internal External Switchover bit (Internal External Switchover mode is enabled)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is enabled)
int main(void)
    INTCONbits.PEIE = 1;
    INTCONbits.GIE = 1;
    T1CONbits.T1CKPS0 = 1;
    T1CONbits.T1CKPS1 = 1;
    PIE1bits.TMR1IE = 1;
    T1CONbits.TMR1ON = 1;
    TRISC = 0;
    PORTC = 0;
    while(1);
void interrupt IRS(void)
    if(PIR1bits.TMR1IF == 1)
        PORTCbits.RC0 ^= 1;
        PIR1bits.TMR1IF = 0;
  • bbolo1
    bbolo1 over 11 years ago
    Hey Jacob,
    I think you forgot to assign the RC0 pin for digital operation. Many of the PIC I/O pins that can work as analog (e.g. ADC or comparator inputs) are assigned for analog operation at power-up.
    Please add the following line before the "while(1)":
    ANSELbits.ANS4 = 0;
    Let me know if it works.
    Cheers
  • MicrochipRTCfr
    MicrochipRTCfr over 11 years ago in reply to bbolo1
    A couple of recommendations :
    1/ To make your software portable among all PICs use :
    #include<xc.h>                //  this is valid for any PIC header for all XC compilers ;=)
    2/ Interrupts
    To make sure your interrupts will always work in case you use several interrupts simultaneously you should use :
    void interrupt ISR(void)
    if(PIR1bits.TMR1IF && PIE1bits.TMR1IE)
    3/ Digital & analog functions
    As mentioned in previous post, analog function are always the default option at reset on PICs. i.e all the ADC analog inputs default to analog mode.
    You must set the ANSEL / ADCON register to declare the pins you want to use in digital mode
    Good tutorial about PICs : 8-Bit PICRegistered Microcontrollers - Developer Help
    regards
    Thanks it works now.
  • MicrochipRTCfr
    MicrochipRTCfr over 11 years ago in reply to e14 Contributor
    Brilliant,
    Good luck with development ;=)
    By the way, PIC16F690 is a quite old PIC16 device.
    The new ones can be easily detected as their name has 4 digits after "F" : like PIC16F1xxx. You can easily find them using the parametric selector MAPS : http://www.microchip.com/MAPS
    They are cheaper, they have much more peripherals, and they can run faster from internal oscillator
    Regards
