Embedded and Microcontrollers
Pic Microcontrollers Forum 12F675 can not programmed  with pickit4
  • Answers 3 answers
  • Subscribers 237 subscribers
  • Views 2067 views
  • i am using 12f675 ic for small project but cant program
patilsatish
patilsatish over 5 years ago
I am using 12F675 ic for small project but cant program it with pickit4? also i am using MPLABIDE V5.2 And XC8 compiler. It will show message C99 File absent for mid range controllers
  • koudelad
    koudelad over 5 years ago in reply to patilsatish +3
    Hello, from the scroll bar on the right, I can see that you are facing multiple errors (marked as red). I would start from the beginning - the first tells you about line 12 and a non existing register…
  • koudelad
    koudelad over 5 years ago in reply to patilsatish +3 suggested
    By the way, you were asking about PIC12F675, but the code is compiled for PIC16F886 - isn't this the issue? I mean, the configuration bits are probably different in some cases like oscillator etc.
  • koudelad
    koudelad over 5 years ago +2 suggested
    Hello, I think you are having a different problem than PIC12F675 not being supported by PICkit4. If you see the product page and switch to Overview tab, there is a link to release notes of MPLAB X . I…
  • koudelad
    0 koudelad over 5 years ago
    I think you are having a different problem than PIC12F675 not being supported by PICkit4. If you see the product page and switch to Overview tab, there is a link to release notes of MPLAB X . I downloaded the archive, extracted and opened the following file: mplabx-ide-release-notes-v5.45/Device Support.htm . It states PIC12F675 as supported by PICkit4 for both programming and debugging (but not the rf version, which you probably don't have).
    From the last sentence you wrote I would guess you have some kind of a compilation error. Could you, please, provide a screenshot?
    David
  • patilsatish
    0 patilsatish over 5 years ago in reply to koudelad
    Thanks For Reply.
                                Actually your guess is right. Now i also facing the problem of compiler also as i reinstalled it. Now MPLABIDE IS V5.20  and  xc8 compiler has version
    2.05. as you told i am sending the screen shot.
  • koudelad
    0 koudelad over 5 years ago in reply to patilsatish
    I would start from the beginning - the first tells you about line 12 and a non existing register - maybe you could paste the source code...
  • koudelad
  • 14rhb
    0 14rhb over 5 years ago
    I recall some issues around xc8 v2.00 that were due to it automatically using C99 but I don't know if that was fixed by v2.05. You could try reverting the project to C90 ?
