Embedded and Microcontrollers
Pic Microcontrollers Forum Can't Blink a LED In PIC 18F4550
  • Subscribers 235 subscribers
  • Views 843 views
  • ccs
  • c
  • microchip
  • 18f
  • 18f4550
  • 50
  • microcontroller
  • 45
  • pic
  • bacon
brv64
brv64 over 12 years ago
I Don't know What I'm doing Wrong
I Have a 4M, 8M, 12M, and 20M Crystals
Tried with those crystals and Nothing.
What am I Missing?
#include <18F4550.h>   //Incluye Libreria del PIC
#FUSES NOWDT,NOPUT,NOPROTECT,BROWNOUT,NOMCLR,NOLVP,NODEBUG //Incluimos los fusibles
#use delay(clock=8000000) //Cristal
#byte PORTA=0x92 //Declara Direcciones de Puertos
#byte PORTB=0x93
#byte PORTC=0x94
#byte PORTD=0x95
#Byte PORTE=0x96
int16 time=1000; //Declaramos Variable tiempo como 500 Integer 16bits
void main()// Inicio del programa
   Set_Tris_D(0b00000000); //Declara las Salidas y entradas
   PORTD=0; //Limpia puerto
   while(1) //Bucle infinito
      PORTD=255; //declaramos que el RD0 esta encendido
      delay_ms(time);//Retardo a la intruccion
      PORTD=0;
      delay_ms(time);
    Solicion I have for you I've been working with assembler and code for the LED would stay well.
    I hope you and serve.
    STATUS equ  03h
    TRISA equ  85h
    PORTA equ  05h
      bsf STATUS,5
      movlw  00h
      movwf TRISA
      bcf STATUS,5
    Inicio movlw  02h
      movwf PORTA
      movlw  00h
      movwf PORTA
      goto Inicio
  • brv64
    0 brv64 over 12 years ago in reply to e14 Contributor
    Thanks a lot for your reply
    It Works Well, But I'm Looking for the correction in CCS C
    n_nU
  • brv64
    Thanks a Lot For Your help
    I Made it Work with this code
    You can use it if you like
    Have fun
    #include <18f4550.h>  //archivo de cabecera
    #fuses HSPLL,MCLR,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,NOVREGEN,NOPBADEN // fuses  configurados
    // el fuse que configuramos anteriormente
    #use delay(clock=20000000)     // el clock que tendremos a la entrada del CPU
    #byte PORTA=0xF80
    #byte PORTB=0xF81
    #byte PORTC=0xF82
    #byte PORTD=0xF83 // RAM address
    #Byte PORTE=0xF84
    int16 M=1000;
    int i;
    byte Const a[10]={0b00111111,
                      0b00000110,
                      0b01011011,
                      0b01001111,
                      0b01100110,
                      0b01101101,
                      0b01111101,
                      0b00000111,
                      0b01111111,
                      0b01100111,};
    void main()
       Set_Tris_B(0b00000000);
       PORTB=0;
       while(1)
          for(i=0;i<10;i++)
                PORTB=a[i];
                delay_ms(M);
