Embedded and Microcontrollers
Pic Microcontrollers Forum pic programming
  • Subscribers 236 subscribers
  • Views 893 views
pic programming
Sir,
I started  doing my project work in pic24ep512gu814.In my programming i need to check all the pins .
BCLR PORTH,#0; next  BCLR PORTH,#1; etc.upto  16 pin.Is it is possible to implement this in a general format (using loop)? Is it is possible  BCLR PORTH,# i  (but   it shows wrong).kindly help me to do this.
Thank you
  • clem57
    0 clem57 over 11 years ago
    If you look up the data sheet, you will find that they are memory mapped. Therefore, looping through the correct addresses, you can "read" the status as you wish. This is dependent on the model of course and a special register..
    Clem
    0 e14 Contributor over 11 years ago in reply to clem57
    Ya it is memory mapped.But sir i need to continuously check all the pins using a reg.(increment the reg.).or like option.But BSET PORTA,W7(increment w7) is not work.Is any method for this.Please help me to move forward
    Thank you
  • clem57
    0 clem57 over 11 years ago in reply to e14 Contributor
    Why are you checking so often? Are you looking for a change? If so, you need to setup an interrupt instead.
    Clem
    Are you looking for this form?  TBLWTH.B[W6++], [W7++]
