Embedded and Microcontrollers
Documents Moving to the ARM®︎ Cortex™︎-M3 from 8-bit Applications
  • Author Author: tech1
  • Date Created: 2 Oct 2009 1:05 PM Date Created
  • Last Updated Last Updated: 7 Oct 2021 12:37 AM
  • Views 575 views
It's time to move from an 8-bit microcontroller into the exciting world of ARM. As an experienced embedded designer, much of what you will encounter in working with StellarisRegistered ARM Cortex-M3 microcontrollers will be familiar—but there are a few things that may require a second look and a trip up the learning curve. This article covers a broad range of topics that intend to ease the transition. For many readers some of the information here states the obvious—if that is the case, at least you will know that you are on the right path.
To read more, please click the attached PDF
imageMoving to the ARM CortexM3 .pdf
  • pt:microcontroller
  • programmable_logic
