Embedded and Microcontrollers
Documents Tech First Kit-Renesas-R0K5212D8S001BE-EVK
  • Author Author: tech2
  • Date Created: 2 Dec 2009 11:07 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:56 AM
  • Views 1617 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The Renesas Starter Kit for R8C/2D is intended as a user-friendly introductory and evaluation tool for the R8C/2D microcontroller. The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E8a emulator and/or Flash Development Toolkit.
The Renesas Starter Kit for R8C/2D may be connected to the host PC using a simple RS232 serial connection or via the included USB E8a on chip debugging interface.
The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools.
Kit Contents
  • LCD MODULE
  • Evaluation board
  • E8a debugger module
Key FeaturesBack to Top
  • more performance in 8bit applications
  • 16 bit CPU core – same as M16C
  • 20MHz - 50ns min. instructions
  • two internal oscillators (125KHz & 40MHz)
    • 40MHz with best accuracy
  • low power consumption
  • 20pin to 80pin packages
  • 4Kbyte to 128kbyte Flash
  • Power on reset & Low voltage detection
  • On chip debugger
Ordering InformationBack to Top
Supplier
Part Number
RENESAS
R0K5212D8S001BER0K5212D8S001BE
Associated Products
SupplierDescriptionSupport DevicePart Number
RENESAS
16-Bit Microcontroller IC
R5F21276
R5F21276SNFP#U0R5F21276SNFP#U0
SCHURTER
SWITCH, PCB, PUSH, IP40
Reset switch
1241.16021241.1602
BOURNS
TRIMMER, 10K
potentiometer
3386F-1-103TLF3386F-1-103TLF
TYCO ELECTRONICS / AMP
PLUG, D, 40-40UNC, 9WAY
connector
3-338168-23-338168-2
Similar Products
RENESAS
Starter Kit for R8C/1B
R5F211B4SP
R0K5211B4S001BER0K5211B4S001BE
RENESAS
Starter Kit for R8C/23
R5F21237JFP
R0K521237S001BER0K521237S001BE
RENESAS
KIT, STARTER, R8C25
R8C/25
R0K521256S001BER0K521256S001BE
RENESAS
KIT, STARTER, R8C27
R8C27
R0K521276S001BER0K521276S001BE
SILICON LABORATORIES
DEVELOPMENT KIT, 16-BIT, 100TQFP
C8051F060, C8051F061, C8051F062 and more
C8051F060DKC8051F060DK
MICROCHIP
BOARD, DEV, 16BIT, NANOWATT XLP
DM240311DM240311
MICROCHIP
DEVELOPMENT BOARD KIT, 16-BIT, 28-PIN
PIC24
DM300027DM300027
FREESCALE SEMICONDUCTOR
16-BIT HCS12DT256 STUDENT LEARNING KIT
HCS12DT256
APS12DT256SLKAPS12DT256SLK
Evaluation Board for the 16-bit MC9S12XE and XS-Families
MC9S12XEP100
EVB9S12XEP100EVB9S12XEP100
16-bit HCS12 DG128 Learning Kit
MC9S12DG128CFUERMC9S12DG128CFUER
LFEBS12UBLABLFEBS12UBLAB
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
R0K521276
R8C/26, R8C/27 Group Datasheet
624KB
R0K521276
R8C/26, R8C/27 Group Hardware Manual
4773KB
Application Notes
File Name
Size
R8C27 Renesas Starter Kit Sample Code
48KB
Perl Script to Convert S-Record Data to a C Structure
631KB
Utility To Convert S-Record Data To A C-Structure
258KB
Rewriting the Data Flash (EW1 Mode, Suspend Operation)
244KB
R8C/2x Series VDE Certified IEC60730 Self Test Code for R8C/2x Series MCU
445KB
R8C Family Renesas LIN Overview
184KB
Hardware & Software
File Name
Size
C Compiler Package for R8C and M16C Families
MISRA C Rule Checker SQMlint
Simulator Debugger for M16C Series and R8C Family
E8a
R0E521276CPE00 (compact emulator)
R0E521276EPB00 (In Circuit programmer)
  • sp:renesas
  • at:evaluation_kit
  • at:tech_first_kit
