Embedded and Microcontrollers
Documents Tech First Kit-Atmel-ATAVRSB200-Battery-Dev Kit
  • Author Author: tech2
  • Date Created: 23 Nov 2009 10:53 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:57 AM
  • Views 810 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The SB200 is a development platform for SB20x smart battery reference designs, which offers an easy way to start evaluation and hence development of smart battery applications using AtmelRegistered AVRRegistered microcontrollers. The SB200 is not in itself a reference design, but is intended to be used with e.g. SB201-1, which is a reference design that demonstrates implementation of a single cell smart battery (Li-Ion).
16340/CR123A battery cells can be inserted in the SB200 battery sockets, and a SB20x is inserted in the dedicated daughter board socket. This forms a “battery pack” with a given number of cells, safety protection and full battery capacity monitoring capabilities. Alternately other cell types can be soldered into the SB200. To simulate the use of the “battery pack” the SB200 features a Charger that can charge the battery pack, and a Constant Current Load that can simulate an application that draws power from the battery pack.
Kit Contents
The ATAVRSB200 Development Kit contains the hardware essentials you will need to use the  ATAVRSB200. The items in the Development Kit and their use are as follows.
  • SB20X
  • SB200 Gateway(USB1287)
Key FeaturesBack to Top
  • Safe use of the SB200 and Li-Ion batteries
  • Examples of use:
  • Charging the batteries
  • Discharging the batteries
  • Reading values from SB201 smart battery
  • Shunt resistor calibration
  • Authentication
  • Data logging
  • Troubleshooting
Ordering InformationBack to Top
Supplier
Part Number
Atmel
ATAVRSB200ATAVRSB200
Associated Products
Supplier
Description
Part Number
AtmelProbe for ATAVRONE
ATAVRONE-PROBEATAVRONE-PROBE
AtmelCable, Probe for ATAVRONE
ATAVRONE-PROBECBLATAVRONE-PROBECBL
AtmelPSU for AVRONE
AVRONE-PSUAVRONE-PSU
AtmelDevelopment Kit, Debug Tool
ATJTAGICE2ATJTAGICE2
AtmelTest Board Kit, Combo
ATJTAGICE2 - JMS2206ATJTAGICE2 - JMS2206
FairchildUHS Universal Configurable 2-Input Logic Gate
NC7SZ57P6XNC7SZ57P6X
Atmel8-Bit Microcontroller with 128k bytes of ISP Flash and USB Controller
AT90USB1287-16MUAT90USB1287-16MU
Similar Products
SupplierDescriptionSupport DevicePart Number
Microchip
MCP7382X Li-Ion Battery Charger Dev tool
MCP7382X
MCP7382XEVMCP7382XEV
Microchip
MCP7384X Li-Ion Battery Charger
MCP7384X
MCP7384XEVMCP7384XEV
Microchip
MCP7386X Li-Ion Battery Charger
MCP7386X
MCP7386XEVMCP7386XEV
TI
BQ24150
BQ24150EVMBQ24150EVM
TI
BQ20Z90EVM-001BQ20Z90EVM-001 Evaluation Module for 2nd Generation Impedance Track(TM)
BQ20Z90
TI
BQ20Z80EVM-001 Impedance Track(TM) Fuel Gauge For LiIon Battery Packs
BQ20Z80
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
ATtiny861/V8-bit Microcontroller with 8K Bytes In-System Programmable300KB
ATmega16HVA8-bit Microcontroller with 16K Bytes In-System Programmable Flash332KB
AT90USB12878-Bit Microcontroller with 128k bytes of ISP Flash and USB Controller4.57MB
NC7SZ57TinyLogic UHS Universal Configurable 2-Input Logic Gates168KB
Application Notes
File Name
Size
ATAVRSB201 User's guide320KB
Firmware User's Guide for SB201-1 & SB201-2376KB
On-The-Go (OTG) add-on to USB164KB
Quick start guide for SB200664KB
Runtime calibration and compensation of RC oscillators100KB
Using the Deep Under-Voltage Recovery Mode (DUVR)80KB
Hardware & Software
File Name
Size
Battery Management Devices398KB
  • at:development_kit
  • ap:battery
  • sp:atmel
  • at:tech_first_kit
