Embedded and Microcontrollers
Documents Tech First Kit-Luminary Micro-EKI-LM3S6965-ARM-EVK
  • Author Author: tech2
  • Date Created: 25 Nov 2009 5:03 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:57 AM
  • Views 2235 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The Stellaris LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. Evaluation Kit provides a compact and versatile evaluation platform for Ethernet enabled Stellaris ARMRegistered CortexTm-M3-based microcontrollers. Each board has an In-Circuit Debug Interface (ICDI) that provides hardware debugging functionality not only for the on-board Stellaris devices, but also for any Stellaris microcontroller-based target board. The evaluation kits contain all cables, software, and documentation needed to develop and run applications for Stellaris microcontrollers easily and quickly.
Kit Contents
The EKI-LM3S6965..EKI-LM3S6965.. Evaluation Kit contains the hardware essentials you will need to use the Kit. The items in the Evaluation Kit and their use are as follows.
  • LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. evaluation board (EVB)
  • Retracting Ethernet cable, USB cable, and 20-pin JTAG/SWD cable
  • CD containing:
    • Complete documentation
    • Evaluation version of the software tools
    • Quickstart guide and source code
    • StellarisWareRegistered Peripheral Driver Library and example source code
  • An evaluation version of one of the following:
    • KeilTm RealViewRegistered Microcontroller Development Kit (MDK-ARM)
    • IAR Embedded Workbench
    • Code Sourcery GCC development tools
    • Code Red Technologies Code Suite development tools
Key FeaturesBack to Top
  • Stellaris LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. microcontroller with fully-integrated 10/100 embedded Ethernet controller
  • Simple setup: USB cable provides serial communication, debugging, and power
  • OLED graphics display
  • User LED, navigation switches, and select pushbuttons
  • Magnetic speaker
  • LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. I/O available on labeled break-out pads
  • Standard ARMRegistered 20-pin JTAG debug connector with input and output modes
  • USB interface for debugging and power supply
  • MicroSD card slot
    Ordering InformationBack to Top
    Supplier
    Part Number
    Luminary Micro
    EKI-LM3S6965EKI-LM3S6965
    Associated Products
    Supplier
    Description
    Part Number
    Luminary Micro
    StellarisRegistered LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. Microcontroller
    LM3S6965LM3S6965
    FTDI
    FT2232D Dual USB UART/FIFO I.C.
    FT2232D/TRFT2232D/TR
    NS
    Low Dropout, Low IQ, 500mA CMOS Linear Regulator
    LP8345CDT-1.8/NOPBLP8345CDT-1.8/NOPB
    Onsemi
    1 kb Microwire Serial EEPROM
    CAT93C46VI-GT3CAT93C46VI-GT3
    Similar Products
    SupplierDescriptionSupport DevicePart Number
    Luminary Micro
    EKC-LM3S6965..EKC-LM3S6965.. Ethernet Evaluation Kit for CodeSourcery G++
    EKC-LM3S6965EKC-LM3S6965
    Luminary Micro
    EKT-LM3S6965 Ethernet Evaluation Kit for Code Red Technologies Red Suite
    EKT-LM3S6965EKT-LM3S6965
    Luminary Micro
    EKK-LM3S6965..EKK-LM3S6965.. Ethernet Evaluation Kit for KeilTm RealViewRegistered
    EKK- LM3S6965EKK- LM3S6965
    Luminary Micro
    EKI-LM3S9B92..EKI-LM3S9B92.. Ethernet+USB-OTG Evaluation Kit for IAR Systems
    LM3S9B92
    EKI-LM3S9B92EKI-LM3S9B92
    Luminary Micro
    EKK-LM3S9B90..EKK-LM3S9B90.. Ethernet+USB-OTG Evaluation Kit for IAR Systems
    LM3S9B90
    EKI-LM3S9B90EKI-LM3S9B90
    Luminary Micro
    DK-LM3S9B96 Development Kit
    LM3S9B96
    DK-LM3S9B96DK-LM3S9B96
    Document ListBack to Top
    Data Sheet
    Part NumberDescriptionSize
    StellarisRegistered LM3S6965 Microcontroller
    6.81MB
    FT2232D
    1.0MB
    LP8345
    665KB
    CAT93C46
    149KB
    Application Notes
    File Name
    Size
    AN01237 Programming the On-Chip Flash Memory in a Stellaris Microcontroller
    95KB
    AN01240 Clocking Options for Stellaris Family Microcontrollers
    107KB
    AN01241 Using a Stellaris Microcontroller as an IO Processor
    138KB
    AN01242 Using the Stellaris Serial Flash Loader
    118KB
    AN01243 Adding 32 KB of Serial SRAM to a Stellaris Microcontroller
    110KB
    AN01244 Evaluating PeerSec Networks’MatrixSSL on a Stellaris Microcontroller
    365KB
    AN01248 Using the Stellaris Boot Loader
    88KB
    AN01249 Upgrading to Luminary Micro’s Stellaris Microcontrollers from Microchip’s PIC Microcontrollers
    124KB
    AN01250 Migrating to the New Members of the Stellaris Family of Microcontrollers
    206KB
    AN01257 Flash Protection for Stellaris Microcontrollers
    95KB
    AN01260 Using the Stellaris Ethernet Controller with Micro IP (uIP)
    73KB
    AN01261 Using the Stellaris Ethernet Controller with Lightweight IP (lwIP)
    72KB
    AN01265 Optimizing Code Performance and Size for Stellaris Microcontrollers
    174KB
    AN01266 Serial-to-Ethernet Converter for Stellaris Microcontrollers
    101KB
    AN01267 Using Stellaris Microcontrollers Internal Flash Memory to Emulate EEPROM
    92KB
    AN01270 Software UART for Stellaris Microcontrollers
    119KB
    AN01271 USB Certification for Stellaris Microcontroller-based USB Peripherals and Embedded Host Systems
    3.9MB
    AN01273 Application Update Using the USB Device Firmware Upgrade Class
    190KB
    AN01274 Configuring Stellaris Microcontrollers with Pin Multiplexing
    153KB
    Hardware & Software
    File Name
    Size
    CMX_Eval_for_CortexM3-Ethernet_and_IAR_tools
    4.07MB
    embos_cm3_iar_trial_v340
    2.03MB
    FreeRTOS demo for LM3Sxxxx with GCC tools
    831KB
    LMFlashProgrammer_819
    5.62MB
    Micrium-LuminaryMicro-uCOS-II-TCPIP-EK-LM3S6965
    2.68MB
    Others Resources
    File Name
    Size
    WP - The Future of the MCU Market
    784KB
    WP - An Introduction to the ARM Cortex-M3 Processor
    346KB
    WP - Motor Control Using a 32-bit Cortex-M3 MCU
    493KB
    WP - 32 BITS for a Buck
    301KB
    WP - Transitioning to Cortex-M3 based MCUs
    476KB
    WP - Moving_to_CortexM-3
    514KB
    Evaluation Kit Quickstart IAR Tools
    328KB
    LM3S6965 Evaluation Kit Readme First
    164KB
    StellarisRegistered LM3S2965 Evaluation Board and LM3S6965 Evaluation Board User’s Manual Documentation Addendum
    30KB
    ProductBrief_6965_EvalKit
    82KB
    • ap:arm
    • sp:luminary_micro
    • at:evaluation_kit
    • at:tech_first_kit
