Embedded and Microcontrollers
Documents Tech First Kit-Luminary Micro-RDK-IDM-SBC-Embedded-EVK
  • Author Author: tech2
  • Date Created: 26 Nov 2009 8:47 AM Date Created
  • Last Updated Last Updated: 27 Oct 2013 5:23 AM
  • Views 1366 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The Luminary Micro StellarisRegistered 3.5-inch Landscape Single Board Computer Intelligent Display Reference Design Kit (RDK-IDM-SBC) offers a complete, open-tool graphical touch-screen user interface design solution for control, automation, and instrumentation applications. Based on the feature-rich Stellaris LM3S9B92 microcontroller featuring Ethernet, USB OTG/Host/Device, and CAN, the new intelligent display module featured in the kit (MDL-IDM-SBC) combines a complete 3.5-inch QVGA landscape-oriented touch-screen user interface with several serial, digital, and analog connectivity options for easy implementation as a Human Machine Interface (HMI) touch display panel in an embedded control device. Software development for the RDK-IDM-SBC is simplified by using Luminary Micro's comprehensive StellarisWareRegistered Peripheral Driver Library, Graphics Library, and USB Library in conjunction with ARM development tools from ARM tools partners.
Kit Contents
The reference design ships with everything needed to quickly evaluate and easily customize the intelligent display module for your specific application, including
  • StellarisRegistered IDM-SBC board
  • MDL-ADA2MDL-ADA2 10-pin to 20-pin adapter
  • USB flash drive (128 MB)
  • 24 V power supply with international plug-set
  • Ethernet cable
  • 8 Ohm speaker
  • CD with tools, documentation and source code including: Quickstart Guide, User’s Manual, Software Reference Manual, Board Data Sheet, BOM, schematics, and Gerber files
Key FeaturesBack to Top
The RDK-IDM-SBC ships with the software-customizable MDL-IDM-L35 module. The MDL-IDM-L35 features the following:
  • Bright QVGA LCD touch-screen display
    • 262K colors, 3.5" QVGA 320 x 240 pixels
    • White LED backlight with resistive touch panel
  • Serial connectivity options
    • USB 2.0 Host
    • 10/100 Ethernet MAC and PHY
    • 1 MBPS Controller Area Network (CAN)
    • I2C Interface for external peripherals and sensors
    • UART serial port with TTL signal levels
  • High performance and memory
    • 32-bit ARMRegistered CortexTm-M3 core
    • 256 KB single-cycle Flash, 96 KB single-cycle SRAM, and 80 MHz operation
  • Versatile board-level memories
    • 8 MB SDRAM connected by EPI
    • 1 MB serial flash connected by SPI
    • microSD card slot
    • USB Host connector for external mass-storage devices
  • Power supply
    • Wide input range 12-40 Vdc power supply with auxiliary 5 V power output
  • I2S mono Codec for high-quality audio with 0.8 W amplifier for external 8-Ohm speaker
  • Screw terminal block for I2C, CAN, and power connections
  • Compact 2.0" x 3.0" PCB footprint
  • Easy to customize
    • Includes full source code, example applications,
    • and design files
    • Develop using tools supporting the IDM-SBC
    • from Keil, IAR, Code Sourcery, and Code Red
    • (using a Stellaris evaluation kit or preferred ARM
    • Cortex-M3 debugger)
    • Supported by Luminary Micro Graphics Library
    • and StellarisWareTm Peripheral Driver Library
    • Comes with factory-programmed quickstart
    • game demo application
    • Ethernet boot loader for firmware update
Ordering InformationBack to Top
Supplier
Part Number
Luminary Micro
RDK-IDM-SBCRDK-IDM-SBC
Associated Products
Supplier
Description
Part Number
Luminary Micro
Microcontroller
LM3S9B92-IQC80-B1LM3S9B92-IQC80-B1
Luminary Micro
10-pin to 20-pin JTAG Adapter Module
MDL-ADA2MDL-ADA2
Similar Products
SupplierDescriptionSupport DevicePart Number
Luminary Micro
2.8" display with PoE open-tooled Reference Design Kit
LM3S6918-IQC50-A2LM3S6918-IQC50-A2
RDK-IDMRDK-IDM
Luminary Micro
3.5" landscape display Reference Design Kit
LM3S1958
RDK-IDM-L35RDK-IDM-L35
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
LM3S9B92
Microcontroller
11.1MB
Application Notes
File Name
Size
Programming the On-Chip Flash Memory in a Stellaris Microcontroller
94.6KB
Clocking options for Stellaris Family Microcontrollers
106KB
Adding 32KB of Serial SRAM to a Stellaris Microcontroller
109KB
Evaluating PeerSec Networks’ MatrixSSL on a Stellaris Microcontroller
364KB
Upgrading to Luminary Micro's Stellaris Microcontrollers from Microchip's PIC Microcontrollers
123KB
Implementing RS-232 Flow Control on a StellarisRegistered Microcontroller
86KB
Using Schematic Part Libraries and PCB Footprint Libraries for StellarisRegistered Microcontrollers
190KB
Using the StellarisRegistered Ethernet Controller with Micro IP (uIP)
72.1KB
Using the StellarisRegistered Ethernet Controller with Lightweight IP (lwIP)
71.3KB
Serial-to-Ethernet Converter for Stellaris Microcontrollers
100KB
Configuring the StellarisRegistered LM3S9B92, LM3S9792, LM3S9B95, and LM3S9B96 Microcontrollers with Pin Multiplexing
152KB
Hardware & Software
File Name
Size
Intelligent Display Module Single-Board Computer RDK User's Manual
456KB
Board Design Package for the RDK-IDM-SBC
744KB
Reference Design Kit CD for the RDK-IDM-SBC
91.4MB
RDK-IDM-SBC Firmware Development Package
28.1MB
Others Resources
File Name
Size
IDM-SBC RDK Quickstart
188KB
  • sp:luminary_micro
  • at:evaluation_kit
  • at:tech_first_kit
  • ap:embedded
