Embedded and Microcontrollers
Documents Tech First Kit-Luminary Micro-EKT-LM3S1968-ARM-EVK
  • Author Author: tech2
  • Date Created: 25 Nov 2009 5:03 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:57 AM
  • Views 892 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
Stellaris LM3S1968-IQC50-A2LM3S1968-IQC50-A2 Evaluation Kits provide a compact and versatile evaluation platform for LM3S1000 Series Stellaris ARMRegistered CortexTm-M3-based microcontrollers. Each board has an In-Circuit Debug Interface (ICDI) that provides hardware debugging functionality not only for the on-board Stellaris devices, but also for any Stellaris microcontroller-based target board. The evaluation kits contain all cables, software, and documentation needed to develop and run applications for Stellaris microcontrollers easily and quickly.
Kit Contents
The EKT-LM3S1968 Evaluation Kit contains the hardware essentials you will need to use the Kit. The items in the Evaluation Kit and their use are as follows.
  • LM3S1968-IQC50-A2LM3S1968-IQC50-A2 evaluation board (EVB)
  • USB cable
  • 20-pin JTAG/SWD target cable
  • CD containing:
    • Complete documentation
    • Evaluation version of the software tools
    • Quickstart guide and source code
    • StellarisWareRegistered Peripheral Driver Library and example source code
    • An evaluation version of one of the following:
    • KeilTm RealViewRegistered Microcontroller Development Kit (MDK-ARM)
    • IAR Embedded Workbench
    • Code Sourcery GCC development tools
    • Code Red Technologies development tools
Key FeaturesBack to Top
  • Stellaris LM3S1968-IQC50-A2LM3S1968-IQC50-A2 microcontroller
  • Simple setup; USB cable provides serial communication, debugging, and power
  • OLED graphics display
  • User LED, navigation switches, and select pushbuttons
  • 8Ω magnetic speaker with class D amplifier
  • Internal 3 V battery and support for on-chip hibernation module
  • USB interface for debugging and power supply
  • Standard ARMRegistered 20-pin JTAG debug connector with input and output modes
  • LM3S1968-IQC50-A2LM3S1968-IQC50-A2 I/O available on labeled break-out pads
    Ordering InformationBack to Top
    Supplier
    Part Number
    Luminary Micro
    EKT-LM3S1968EKT-LM3S1968
    Associated Products
    Supplier
    Description
    Part Number
    Luminary Micro
    StellarisRegistered LM3S1968-IQC50-A2LM3S1968-IQC50-A2 Microcontroller
    LM3S1968-IQC50LM3S1968-IQC50
    FTDI
    FT2232D Dual USB UART/FIFO I.C.
    FT2232D/TRFT2232D/TR
    NS
    Micropower, 300mA Ultra Low-Dropout CMOS Voltage Regulator
    LP3981ILD-3.3LP3981ILD-3.3
    Onsemi
    1 kb Microwire Serial EEPROM
    CAT93C46VI-GT3CAT93C46VI-GT3
    Fairchild
    High Efficiency Serial LED Driver and OLED Supply with 20V Integrated Switch
    FAN5331SXFAN5331SX
    Similar Products
    SupplierDescriptionSupport DevicePart Number
    Luminary Micro
    EKC-LM3S1968..EKC-LM3S1968.. Evaluation Kit for CodeSourcery G++
    EKC-LM3S1968EKC-LM3S1968
    Luminary Micro
    EKT-LM3S1968 Evaluation Kit for IAR Embedded Workbench
    EKI-LM3S1968EKI-LM3S1968
    Luminary Micro
    EKK-LM3S1968..EKK-LM3S1968.. Evaluation Kit for KeilTm RealViewRegistered
    EKK- LM3S1968EKK- LM3S1968
    Document ListBack to Top
    Data Sheet
    Part NumberDescriptionSize
    StellarisRegistered LM3S1968 Microcontroller
    6.38MB
    FT2232D
    1.0MB
    LP3981
    719KB
    CAT93C46
    149KB
    FAN5331SXFAN5331SX
    583KB
    Application Notes
    File Name
    Size
    AN01237 Programming the On-Chip Flash Memory in a Stellaris Microcontroller
    95KB
    AN01240 Clocking Options for Stellaris Family Microcontrollers
    107KB
    AN01241 Using a Stellaris Microcontroller as an IO Processor
    138KB
    AN01242 Using the Stellaris Serial Flash Loader
    118KB
    AN01243 Adding 32 KB of Serial SRAM to a Stellaris Microcontroller
    110KB
    AN01244 Evaluating PeerSec Networks’MatrixSSL on a Stellaris Microcontroller
    365KB
    AN01248 Using the Stellaris Boot Loader
    88KB
    AN01249 Upgrading to Luminary Micro’s Stellaris Microcontrollers from Microchip’s PIC Microcontrollers
    124KB
    AN01250 Migrating to the New Members of the Stellaris Family of Microcontrollers
    206KB
    AN01257 Flash Protection for Stellaris Microcontrollers
    95KB
    AN01260 Using the Stellaris Ethernet Controller with Micro IP (uIP)
    73KB
    AN01261 Using the Stellaris Ethernet Controller with Lightweight IP (lwIP)
    72KB
    AN01265 Optimizing Code Performance and Size for Stellaris Microcontrollers
    174KB
    AN01266 Serial-to-Ethernet Converter for Stellaris Microcontrollers
    101KB
    AN01267 Using Stellaris Microcontrollers Internal Flash Memory to Emulate EEPROM
    92KB
    AN01270 Software UART for Stellaris Microcontrollers
    119KB
    AN01271 USB Certification for Stellaris Microcontroller-based USB Peripherals and Embedded Host Systems
    3.9MB
    AN01273 Application Update Using the USB Device Firmware Upgrade Class
    190KB
    Hardware & Software
    File Name
    Size
    LM3S1968 Evaluation Kit for Code Red Technologies CD
    181MB
    GUI and command line flash programmer
    5.49MB
    EK-LM3S1968 Firmware Development Package
    7.13MB
    FreeRTOS demo for EKT-LM3Sxxxx
    825KB
    Others Resources
    File Name
    Size
    WP - The Future of the MCU Market
    784KB
    WP - An Introduction to the ARM Cortex-M3 Processor
    346KB
    WP - Motor Control Using a 32-bit Cortex-M3 MCU
    493KB
    WP - 32 BITS for a Buck
    301KB
    WP - Transitioning to Cortex-M3 based MCUs
    476KB
    WP - Moving_to_CortexM-3
    514KB
    Quickstart-Eval-Kit-CodeRed
    623KB
    LM3S1968 Evaluation Kit Readme First
    139KB
    ProductBrief_1968_EvalKit
    82KB
    • ap:arm
    • sp:luminary_micro
    • at:evaluation_kit
    • at:tech_first_kit
