Embedded and Microcontrollers
Documents Tech First Kit-Luminary Micro-RDK-IDM-L35-Embedded-EVK
  • Author Author: tech2
  • Date Created: 26 Nov 2009 8:47 AM Date Created
  • Last Updated Last Updated: 27 Oct 2013 8:43 AM
  • Views 786 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The Luminary Micro StellarisRegistered 3.5-inch Landscape Intelligent Display Reference Design Kit (RDK-IDM-L35..RDK-IDM-L35..) offers a complete, open-tool graphical touch-screen user interface design solution for control, automation, and instrumentation applications. Based on the feature-rich Stellaris LM3S1958 microcontroller, the new intelligent display module featured in the kit (MDL-IDM-L35) combines a complete 3.5-inch QVGA landscape-oriented touch-screen user interface with several serial, digital, and analog connectivity options for easy implementation as a Human Machine Interface (HMI) touch display panel in an embedded control device. Software development for the RDK-IDM-L35..RDK-IDM-L35.. is simplified by using Luminary Micro's comprehensive StellarisWareRegistered Peripheral Library and Graphics Library in conjunction with ARM development tools from ARM tools partners.
Kit Contents
The reference design ships with everything needed to quickly evaluate and easily customize the intelligent display module for your specific application, including
  • StellarisRegistered Intelligent QVGA 3.5” Touch Panel Module (MDL-IDM-L35) with metal standoffs
  • USB to TTL serial cable to simultaneously power the board and connect to the LM3S1958 Stellaris microcontroller via UART0
  • JTAG debug adapter for 10-pin fine-pitch connection to a standard 20-pin connector
  • Quickstart Guide, User’s Manual, Software Reference Manual, Board Data Sheet, source code, BOM, schematics, and Gerber files on CD
Key FeaturesBack to Top
The RDK-IDM ships with the software-customizable MDL-IDM-L35 module. The MDL-IDM-L35 features the following:
  • Bright QVGA LCD touch-screen display
    • 3.5" QVGA 320 x 240 pixels
    • 262K colors
    • White LED backlight
    • Resistive touch panel
  • Serial connectivity options
    • RS232 serial port with RS232 signal levels
    • UART serial port with TTL signal levels
  • High performance and memory
    • Built around a Stellaris LM3S1958 microcontroller
    • 32-bit ARMRegistered CortexTm-M3 core
    • 256 KB Main Flash memory, 64 KB SRAM
    • microSD slot (typically 1-2 GB storage)
  • Flexible power supply options
    • 5 V power supply with DC regulator that generates 3.3 V for powering the board
  • Easy to customize - full source code and design files including:
    • Schematics and BOM
    • Gerber files
    • Example applications included
  • Develop using development tools from Keil, IAR, Code Sourcery, Code Red Technologies, and GCC
    • Supported by Luminary Micro Graphics Library
    • Supported by Stellaris Peripheral Driver Library
Ordering InformationBack to Top
Supplier
Part Number
Luminary Micro
RDK-IDM-L35RDK-IDM-L35
Associated Products
Supplier
Description
Part Number
Luminary Micro
Intelligent Display Module 3.5" Landscape
MDL-IDM-L35MDL-IDM-L35
Luminary Micro
Microcontroller
LM3S1958LM3S1958
Similar Products
SupplierDescriptionSupport DevicePart Number
Luminary Micro
2.8" display with PoE open-tooled Reference Design Kit
LM3S6918-IQC50-A2LM3S6918-IQC50-A2
RDK-IDMRDK-IDM
Luminary Micro
3.5" landscape display Single Board Computer Reference Design Kit
LM3S9B92
RDK-IDM-SBCRDK-IDM-SBC
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
3.5-inch Landscape Intelligent Display Module RDK
434KB
LM3S1958
Microcontroller
5.64MB
Application Notes
File Name
Size
Programming the On-Chip Flash Memory in a Stellaris Microcontroller
94.6KB
ADC Over Sampling Techniques
188KB
Upgrading to Luminary Micro's Stellaris Microcontrollers from Microchip's PIC Microcontrollers
123KB
Migrating to the New Members of the StellarisRegistered Family of Microcontrollers
205KB
Using Schematic Part Libraries and PCB Footprint Libraries for StellarisRegistered Microcontrollers
190KB
Optimizing Code Performance and Size for Stellaris Microcontrollers
173KB
Using the IEC 60730 Standard for Safe and Reliable Operation of StellarisRegistered Microcontrollers
86.5KB
Hardware & Software
File Name
Size
RDK-IDML35 Board package
1MB
RDK-IDM-L35 Kit CD
60.5MB
RDK-IDM-L35 Firmware Development Package
10.5MB
Others Resources
File Name
Size
IDM-L35 RDK Product Brief
266KB
Intelligent Display Module (IDM-L35) with 3.5" Landscape Display RDK User's Manual
745KB
IDM-L35 RDK Quick Start
521KB
RDK-IDML35 board package
1MB
  • sp:luminary_micro
  • at:evaluation_kit
  • at:tech_first_kit
  • ap:embedded
