Embedded and Microcontrollers
Documents Tech First Kit-Atmel-EVK2160A-Touch Sensor Controller-EVK
  • Author Author: tech5
  • Date Created: 25 Nov 2009 9:52 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:57 AM
  • Views 1453 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The EVK2160A allows the user to evaluate all functions of the QT2160 touch sense controller. The kit provides a convenient reference design and allows the user to visualize discrete touch buttons or a touch slider LED control. The EVK2160A works stand-alone but can also be connected to a PC. The device comes fully assembled, tested and documented.
The EVK2160A can be connected to a PC using the 9206 USB Plug-in card. The EVK2160A software can be used to configure a number of device parameters and evaluate the operation of the device.
Kit Contents
The EVK2160A Evaluation Kit contains the hardware essentials you will need to use the Kit. The items in the Evaluation Kit and their use are as follows.
  • 1x EVK2160A Assembly (EVK2160A Evaluation Board in molded box)
  • 1x CR2032 Battery, 3V, 235mAh
  • 2x Sample AT42QT2160-MMU ICs
  • 1x EVK2160A User Guide
Key FeaturesBack to Top
  • Number of keys: up to 16 keys, and one slider (constructed from 2 to 8 keys)
  • Number of I/O lines: 11 (3 dedicated - configurable for input or output, 8 shared - output only), PWM control for LED driving
  • Slider design: 2 to 8 keys placed in sequence, same design as keys
  • Electrode design: two-part electrode shapes (drive-receive); wide variety of possible layouts
  • Key sensitivity: individually settable via simple commands over I2C-compatible interface
  • Interface: I2C-compatible slave mode (100kHz)
  • Signal processing: self-calibration, auto drift compensation, noise filtering, Adjacent Key Suppression technology
  • Low operating voltage 1.8 to 5.5 V
  • Package: 28-pin 4 x 4 mm MLF RoHS compliant
Ordering InformationBack to Top
Supplier
Part Number
Atmel
EVK2160AEVK2160A
Associated Products
Supplier
Description
Part Number
Atmel
QSlide, 16-key QMatrix Sensor IC
AT42QT2160-MMUAT42QT2160-MMU
Atmel
8-bit Microcontroller with 4-Kbyte Flash
AT89C4051-24SUAT89C4051-24SU
Similar Products
SupplierDescriptionSupport DevicePart Number
Atmel
EVK1060A Evaluation Board
AT42QT1060
EVK1060AEVK1060A
Freescale
Evaluation Kit for the MC33941 in Touch Sensing Applications
MC33941
KITMC33941EVMKITMC33941EVM
Cypress
CapSense Express Evaluation Kit
CY8C201A0
CY3218-CAPEXP2CY3218-CAPEXP2
Cypress
CapSense Express Development Kit
CY8C20142, CY8C201A0, CY8C20140
CY3218-CAPEXP1CY3218-CAPEXP1
Microchip
mTouch Capacitive Evaluation Kit
PIC16F727, PIC24FJ64GB106
DM183026DM183026
ST
STEVAL-IFP004V1 Digital input termination PCLT2
PCLT2
STEVAL-IFP004V1STEVAL-IFP004V1
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
AT42QT2160
QSlide, 16-key QMatrix Sensor IC AT42QT2160
1.22MB
AT89C4051-24SU
1.59MB
Application Notes
File Name
Size
ANKD01_QMatrix Panel Design Guidelines
427KB
ANKD02_Secrets of a Successful Qtouch Design
424KB
ANKD03_Using Philipp Springs to Create Touch Keys
205KB
QTAN0015_Power Supply Considerations for Atmel Capacitive-touch ICs
65KB
QTAN0016_Diagnostic Modes for Products with Atmel Capacitive-touch ICs
67KB
QTAN0017_Check the Effects of External Noise on Atmel Capacitive-touch ICs
273KB
QTAN0030_Implementing a Long Slide Control Using a QMatrix IC
721KB
QTAN0031_Avoiding False Touch Inputs Using Atmel Capacitive Touch Sense ICs
245KB
QTAN0040_Driving the AT42QT2160 QMatrix Sensor IC
145KB
Hardware & Software
File Name
Size
EVK2160A Demonstration Software.exe
2.82MB
Others Resources
File Name
Size
Touch Sensors Design Guide
1.18MB
QMatrix Technology White Paper
388KB
Software GUI for the EVK2160A Demonstration Kit User Guide
943KB
USB Plug-in Card for the EVK2160A Demonstration Kit User Guide
594KB
  • sp:atmel
  • at:evaluation_kit
  • ap:capacitive_touch
