Embedded and Microcontrollers
Documents Tech First Kit-Luminary Micro-EKT-LM3S6965-Ethernet-EVK
  • Author Author: tech2
  • Date Created: 25 Nov 2009 12:52 PM Date Created
  • Last Updated Last Updated: 27 Oct 2013 5:23 AM
  • Views 904 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The StellarisRegistered LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. Ethernet Evaluation Kit is a compact and versatile evaluation platform for the Stellaris LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. ARMRegistered CortexTm-M3-based microcontroller. The evaluation kit uses the LM3S6965microcontroller’s fully integrated 10/100 Ethernet controller to demonstrate an embedded web server.
The LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. evaluation board can be used as an evaluation platform or as a low-cost in-circuit debug interface (ICDI). In debug interface mode, the on-board microcontroller is bypassed, allowing connection of the debug signals to an external target. The kit is also compatible with high-performance external JTAG debuggers.
This evaluation kit enables quick evaluation, prototype development, and creation of application-specific designs for Ethernet networks. The kit also includes extensive source-code examples, allowing you to start building C-code applications quickly.
Kit Contents
The evaluation kit contains everything needed to develop and run applications for Stellaris microcontrollers including:
  • LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. evaluation board (EVB)
  • Retracting Ethernet cable, USB cable, and 20-pin JTAG/SWD cable
  • CD containing:
    • Complete documentation
    • Evaluation version of the software tools
    • Quickstart guide and source code
    • StellarisWareRegistered Peripheral Driver Library and example source code
    • An evaluation version of one of the following:
    • KeilTm RealViewRegistered Microcontroller Development Kit (MDK-ARM)
    • IAR Embedded Workbench
    • Code Sourcery GCC development tools
    • Code Red Technologies development tools
Key FeaturesBack to Top
The evaluation kit includes the following features:
  • Stellaris LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. microcontroller with fully-integrated 10/100 embedded Ethernet controller
  • controller
  • Simple setup; USB cable provides serial communication, debugging, and power
  • OLED graphics display
  • User LED, navigation switches, and select pushbuttons
  • Magnetic speaker
  • LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. I/O available on labeled break-out pads
  • Standard ARMRegistered 20-pin JTAG debug connector with input and output modes
  • USB interface for debugging and power supply
  • MicroSD card slot
    Ordering InformationBack to Top
    Supplier
    Part Number
    Luminary Micro
    EKT-LM3S6965EKT-LM3S6965
    Associated Products
    Supplier
    Description
    Part Number
    Luminary Micro
    Stellaris LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. Microcontroller Industrial Temperature 100-pin LQFP
    LM3S6965-IQC50-A2LM3S6965-IQC50-A2
    FTDI
    Dual USB UART/FIFO I.C.
    FT2232D/TRFT2232D/TR
    Fairchild
    High Efficiency Serial LED Driver and OLED Supply with 20V Integrated Switch
    FAN5331SXFAN5331SX
    Lattice Semiconductor
    3.3V/2.5V/1.8V In-System Programmable SuperFAST High Density PLDs
    LC4032V-75TN48C LC4032V-75TN48C
    Similar Products
    SupplierDescriptionSupport DevicePart Number
    Luminary Micro
    Stellaris LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. Ethernet Evaluation Kit for KeilTm RealViewRegistered MDK-ARM (16 KB code-size limited)
    EKK-LM3S6965EKK-LM3S6965
    Luminary Micro
    Stellaris LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. Ethernet Evaluation Kit for IAR Systems Embedded WorkbenchRegistered (32 KB codesize limited)
    EKI-LM3S6965EKI-LM3S6965
    Luminary Micro
    Stellaris LM3S6965-IQC50-A2.LM3S6965-IQC50-A2. Ethernet Evaluation Kit for CodeSourcery G++ GNU (30-day limited)
    EKC-LM3S6965EKC-LM3S6965
    Document ListBack to Top
    Data Sheet
    Part NumberDescriptionSize
    LM3S6965 Microcontroller Datasheet
    6.85MB
    FT2232D/TR
    0.99MB
    FAN5331SXFAN5331SX
    584KB
    LC4032V-75TN48C
    364KB
    Application Notes
    File Name
    Size
    Programming the On-Chip Flash Memory in a Stellaris Microcontroller
    94.6KB
    ADC Oversampling Techniques
    188KB
    Clocking options for Stellaris Family Microcontrollers
    106KB
    Using a Stellaris Microcontroller as an I/O Processor
    137KB
    Adding 32KB of Serial SRAM to a Stellaris Microcontroller
    109KB
    Evaluating PeerSec Networks’ MatrixSSL on a Stellaris Microcontroller
    364KB
    Using the Stellaris Microcontroller Analog-to-Digital Converter
    364KB
    Upgrading to Luminary Micro's Stellaris Microcontrollers from Microchip's PIC Microcontrollers
    181KB
    Migrating to the New Members of the StellarisRegistered Family of Microcontrollers
    205KB
    Implementing RS-232 Flow Control on a StellarisRegistered Microcontroller
    86.0KB
    Using Schematic Part Libraries and PCB Footprint Libraries for StellarisRegistered Microcontroller
    190KB
    Flash Protection for StellarisRegistered Microcontroller
    94.6KB
    Using the StellarisRegistered Ethernet Controller with Micro IP (uIP)
    157KB
    Using the StellarisRegistered Ethernet Controller with Lightweight IP (lwIP)
    152KB
    Optimizing Code Performance and Size for Stellaris Microcontrollers
    173KB
    Serial-to-Ethernet Converter for Stellaris Microcontrollers
    100KB
    Using Stellaris Microcontrollers Internal Memory to Emulate EEPROM
    91.4KB
    Software UART for StellarisRegistered Microcontrollers
    118KB
    Using the IEC 60730 Standard for Safe and Reliable Operation of StellarisRegistered Microcontrollers
    86.5KB
    Hardware & Software
    File Name
    Size
    LM3S6965 Evaluation Kit Readme First
    319KB
    StellarisRegistered LM3S2965 Evaluation Board and LM3S6965 Evaluation Board User’s Manual Documentation Addendum
    29.3KB
    LM3S6965 Evaluation Kit for Code Red Technologies CD
    184KB
    GUI and command line flash programmer
    5.49MB
    EK-LM3S6965 Firmware Development Package for Revision A boards
    13.9MB
    EK-LM3S6965 RevC Firmware Development Package
    15.9MB
    • ap:ethernet
    • sp:luminary_micro
    • at:evaluation_kit
    • at:tech_first_kit
