Embedded and Microcontrollers
Documents Tech First Kit-BlueTechnix-CMBF548DA-Blackfin Processor-EVK
  • Author Author: tech4
  • Date Created: 26 Nov 2009 7:00 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:57 AM
  • Views 839 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The DEV-BF548-Lite Development Board is designed as a development and application board for the high performance CM-BF548 Core Module. It supports the USB OTG2.0 capability of the CM-BF548 Core Module and adds the feature of a 10/100Mbit industrial Ethernet controller. The development boards provide all interfaces on dedicated connectors or expansion connectors. Extender boards can be plugged on top of the Development Board in order to enable additional interfaces.
Kit Contents
  • DEV-BF548DA-Lite or DEV-BF548-Lite Board
  • 1x USB Cable (USB A/B)
  • 1x USB Cable (USB A/B) (DEV-BF548DA-Lite only)
  • 1x USB Cable (USB A/Mini USB)
  • 1x Ethernet Cable
  • 1x Power Supply
  • Support CD
Key FeaturesBack to Top
  • Dimension: 100X100mm
  • Socket for: CM-BF548 (41X31mm)
  • 3.3V and 5V (1.5A) power supply
  • Buttons and Leds
  • USB-to-UART Converter
  • SMSC 9217 Ethernet controller
  • CAN transceiver and connector
  • SD- Card Socket
  • USB2.0 OTG Connector
  • On- Board Debug Agent
  • JTAG Connector for external Debug Agent
Ordering InformationBack to Top
Supplier
Part Number
BLUETECHNIX
DEV-BF548DA-LITEDEV-BF548DA-LITE
Associated Products
Supplier
Description
Part Number
ANALOG DEVICES
533 MHz Blackfin Embedded Processor
ADSP-BF548BBCZADSP-BF548BBCZ
BLUETECHNIX
BLACKFIN BOARD
DEV-BF548-LITEDEV-BF548-LITE
BLUETECHNIX
BLACKFIN BOARD
BLUETECHNIX
BLACKFIN EXTENDER BOARD
EXT-BF548-EXPEXT-BF548-EXP
BLUETECHNIX
EXT-BF5XX-EXPEXT-BF5XX-EXP
Similar Products
SupplierDescriptionSupport DevicePart Number
BLUETECHNIX
MODULE, BLACKFIN CORE
ADSP-BF527
CM-BF527CM-BF527
BLUETECHNIX
ADSP-BF533
CM-BF533CM-BF533
BLUETECHNIX
ADSP-BF537
CM-BF537ECM-BF537E
BLUETECHNIX
ADSP-BF537
TCM-BF537TCM-BF537
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
ADSP-BF548
3.71MB
MT46V32M16BN-6IT
64 MB DDR SDRAM
3.66MB
Application Notes
File Name
Size
Using the NAND Flash Controller on Blackfin Processors
2.5MB
Putting ADSP-BF54x Blackfin Processor Booting into Practice
151KB
UART Enhancements on ADSP-BF54x Blackfin Processors
81KB
Changing the PHY in the Ethernet Driver for Blackfin Processors
132KB
Blackfin Processor Troubleshooting Tips Using VisualDSP++ Tools
223KB
Hardware & Software
File Name
Size
BlackSheep VDK
817KB
boot loader and uClinux – Download required boot loader and uClinux
  • at:evaluation_kit
  • sp:bluetechnix
  • ap:blackfin_processor
  • at:tech_first_kit
