Embedded and Microcontrollers
Documents Tech First Kit-Luminary Micro-EKC-LM3S9B92-ARM-EVK
  • Author Author: tech2
  • Date Created: 24 Nov 2009 6:08 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:57 AM
  • Views 675 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The StellarisRegistered LM3S9B92 Ethernet+USB-OTG Evaluation Kit provides a low-cost evaluation platform for the LM3S9B92 ARMRegistered CortexTm-M3-based microcontroller. The kit includes two boards: the EK-LM3S9B92 evaluation board, and an In-Circuit Debug Interface (ICDI) board. The evaluation board features a simple, streamlined design for 32-bit Stellaris-based application with industrial connectivity, highlighting the Stellaris LM3S9B92 microcontroller’s simultaneous integrated 10/100 Ethernet MAC/PHY, full-speed USB-OTG interfaces, and convenient connection to the MCU's GPIO ports.
Kit Contents
The EKC-LM3S9B92..EKC-LM3S9B92.. Evaluation Kit contains the hardware essentials you will need to use the Kit. The items in the Evaluation Kit and their use are as follows.
  • EK-LM3S9B92 Evaluation Board (EVB)
  • In-Circuit Debug Interface Board (ICDI)
    • Connects to USB port on PC and to 10-pin ARM JTAG connector on the evaluation board
    • 8-pin Power/UART connector provides power and virtual comm-port to the evaluation board
  • Cables
    • SB-miniB to USB-A plug cable
    • USB-µA to USB-A receptacle cable
    • USB-µB to USB-A plug cable
    • 10-pin ribbon cable for JTAG/SWD connection
    • 8-pin ribbon cable for power/UART connection
  • Evaluation Kit CD containing:
    • Complete documentation, including Quickstart and User's Manual
    • Complete source code and schematics
    • StellarisWareRegistered software including peripheral driver library and example source code
    • CodeSourcery Sourcery G++ GNU with a 30-day evaluation license
Key FeaturesBack to Top
  • Kit includes two boards for a simple out-of-the-box experience: an In-Circuit Debug Interface board and the 36mm x 102mm EK-LM3S9B92 evaluation board
  • The Stellaris LM3S9B92 high-performance microcontroller with large memory
    • 32-bit ARMRegistered CortexTm-M3 core
    • 256 KB main Flash memory, 96 KB SRAM, and ROM loaded with StellarisWareRegistered software
  • For applications requiring more simultaneous access to peripherals and advanced motion control, the 80 MHz LM3S9B92 MCU features eight PWM outputs for motion and energy and two Quadrature Encoder Inputs (QEI) modules, along with options for maximal peripheral connectivity
  • Integrated advanced connectivity peripherals including Ethernet 10/100 with two LED indicators and USB 2.0 Full-Speed OTG
  • Standard size terminal headers for all MCU I/O for ease of prototyping
  • Complete source code, documentation and CodeSourcery Sourcery G++ GNU with a 30-day evaluation license
    Ordering InformationBack to Top
    Supplier
    Part Number
    Luminary Micro
    EKC-LM3S9B92EKC-LM3S9B92
    Associated Products
    Supplier
    Description
    Part Number
    Luminary Micro
    StellarisRegistered LM3S9B92 Microcontroller
    LM3S9B92LM3S9B92
    FTDI
    FT2232D Dual USB UART/FIFO I.C.
    FT2232D/TRFT2232D/TR
    TI
    Single, Current-Limited, Power-Distribution Switch
    TPS2051BDTPS2051BD
    Onsemi
    1 kb Microwire Serial EEPROM
    CAT93C46VI-GT3CAT93C46VI-GT3
    Similar Products
    SupplierDescriptionSupport DevicePart Number
    Luminary Micro
    EKK-LM3S9B92..EKK-LM3S9B92.. Ethernet+USB-OTG Evaluation Kit for KeilTm RealViewRegistered
    LM3S9B92
    EKK-LM3S9B92EKK-LM3S9B92
    Luminary Micro
    EKI-LM3S9B92..EKI-LM3S9B92.. Ethernet+USB-OTG Evaluation Kit for IAR Systems Embedded WorkbenchRegistered
    LM3S9B92
    EKI-LM3S9B92EKI-LM3S9B92
    Luminary Micro
    EKT-LM3S9B92..EKT-LM3S9B92.. Ethernet+USB-OTG Evaluation Kit for Code Red Technologies Red Suite
    LM3S9B92
    EKT-LM3S9B92EKT-LM3S9B92
    Luminary Micro
    EKK-LM3S9B90..EKK-LM3S9B90.. Ethernet+USB-OTG Evaluation Kit for KeilTm RealViewRegistered
    LM3S9B90
    EKK-LM3S9B90EKK-LM3S9B90
    Luminary Micro
    EKK-LM3S9B90..EKK-LM3S9B90.. Ethernet+USB-OTG Evaluation Kit for CodeSourcery G++
    LM3S9B90
    EKC-LM3S9B90EKC-LM3S9B90
    Luminary Micro
    EKK-LM3S9B90..EKK-LM3S9B90.. Ethernet+USB-OTG Evaluation Kit for IAR Systems
    LM3S9B90
    EKI-LM3S9B90EKI-LM3S9B90
    Luminary Micro
    DK-LM3S9B96 Development Kit
    LM3S9B96
    DK-LM3S9B96DK-LM3S9B96
    Document ListBack to Top
    Data Sheet
    Part NumberDescriptionSize
    LM3S9B92
    11.1MB
    FT2232D
    1.0MB
    TPS2051B
    1.72MB
    CAT93C46
    149KB
    Application Notes
    File Name
    Size
    AN01237 Programming the On-Chip Flash Memory in a Stellaris Microcontroller
    95KB
    AN01240 Clocking Options for Stellaris Family Microcontrollers
    107KB
    AN01241 Using a Stellaris Microcontroller as an IO Processor
    138KB
    AN01242 Using the Stellaris Serial Flash Loader
    118KB
    AN01243 Adding 32 KB of Serial SRAM to a Stellaris Microcontroller
    110KB
    AN01248 Using the Stellaris Boot Loader
    88KB
    AN01249 Upgrading to Luminary Micro’s Stellaris Microcontrollers from Microchip’s PIC Microcontrollers
    124KB
    AN01250 Migrating to the New Members of the Stellaris Family of Microcontrollers
    206KB
    AN01257 Flash Protection for Stellaris Microcontrollers
    95KB
    AN01265 Optimizing Code Performance and Size for Stellaris Microcontrollers
    174KB
    AN01267 Using Stellaris Microcontrollers Internal Flash Memory to Emulate EEPROM
    92KB
    AN01270 Software UART for Stellaris Microcontrollers
    119KB
    AN01271 USB Certification for Stellaris Microcontroller-based USB Peripherals and Embedded Host Systems
    3.9MB
    AN01273 Application Update Using the USB Device Firmware Upgrade Class
    190KB
    AN01274 Configuring Stellaris Microcontrollers with Pin Multiplexing
    153KB
    Hardware & Software
    File Name
    Size
    Micro Digital smxUSBH for EK-LM3S9B9x.zip
    109KB
    Micro Digital smxUSBD for EK-LM3S9B9x.zip
    151KB
    FreeRTOS demo for LM3Sxxxx with GCC tools
    1.4MB
    Others Resources
    File Name
    Size
    WP - The Future of the MCU Market
    784KB
          • ap:arm
          • sp:luminary_micro
          • at:evaluation_kit
          • at:tech_first_kit
