Embedded and Microcontrollers
Documents Tech First Kit-Atmel-ATSAM3U-EK-ARM-EVK
  • Author Author: tech5
  • Date Created: 24 Nov 2009 6:36 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:57 AM
  • Views 1293 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The SAM3U Evaluation Kit (SAM3U-EK) allows the evaluation of the SAM3U series devices. It has enough features to demonstrate most of the product’s capabilities to the users. The SAM3U-EK also features extension connectors to allow the users to add new interfaces in case they are not on-board.
The SAM3U-EK board is based on the integration of an ARMRegistered CortexRegistered-M3 processor with on-board fast PSRAM (pseudo-static RAM), NAND-Flash and a set of popular peripherals. It is designed to provide a high performance processor evaluation solution with high flexibility for various kinds of applications.
Kit Contents
The AtmelRegistered SAM3U-EK toolkit contains the following items:
  • A SAM3U-EK board
  • Power supply
  • Universal input AC/DC power supply with US, Europe and UK plug adapters
  • One 3V Lithium Battery type CR1225
  • One USB cable
  • One serial RS232 cable
  • A Welcome Letter
Key FeaturesBack to Top
  • SAM3U4E QFP chip with optional socket footprint
  • 12 MHz crystal
  • 32.768 KHz crystal
  • Optional SMB connector, for external system clock input
  • PSRAM
  • NAND-Flash
  • Backup Battery
  • 2.8 inch TFT color LCD display with touch-panel and backlight
  • UART port with level shifter IC
  • USART port with level shifter IC
  • Audio codec with input and output jacks: stereo headphone out, stereo line in, mono microphone in
  • SD/MMC interface
  • 3-D accelerometer sensor
  • Temperature sensor
  • Reset and Wake-Up buttons: NRST, NRSTB, FWUP
  • User buttons: Left and Right
  • High Speed USB device port
  • JTAG port
  • On-board power regulation with shutdown control (by the SAM3 chip)
  • Two user LEDs
  • Power LED
  • BNC connectors for ADC input
  • User potentiometer connected to the ADC input
  • ZigBeeRegistered connector
  • 3x32 bit PIO connection interfaces (PIOA, PIOB, PIOC)
Ordering InformationBack to Top
Supplier
Part Number
Atmel
ATSAM3U-EKATSAM3U-EK
Associated Products
Supplier
Description
Part Number
Atmel
ICE for AT91 ARM Cores
AT91SAM-ICEAT91SAM-ICE
Atmel
Development Kit, Debug Tool
ATJTAGICE2ATJTAGICE2
Atmel
Test Board Kit, Combo
ATJTAGICE2-JMS2206ATJTAGICE2-JMS2206
Microchip
Temperature Sensor
MCP9800A0T-M/OTMCP9800A0T-M/OT
TI
Touch screen controller
ADS7843EG4ADS7843EG4
Micrel
Low-dropout regulator
MIC29150-3.3BUMIC29150-3.3BU
Freescale
Three Axis Low-g Accelerator sensor
MMA7341LR1MMA7341LR1
TI
RS-232RS-232 Transceiver
MAX3232CDMAX3232CD
Wolfson
Audio CODEC Driver
WM8731SEDSWM8731SEDS
Similar Products
SupplierDescriptionSupport DevicePart Number
Atmel
Evaluation for AT91SAM926EJ
AT91SAM9261
AT91SAM9261-EKAT91SAM9261-EK
Atmel
Evaluation for AT91SAM9263
AT91SAM9263
AT91SAM9263-EKAT91SAM9263-EK
Atmel
Evaluation for AT91SAM9RL-EK
AT91SAM9RL
AT91SAM9RL-EKAT91SAM9RL-EK
TI
LM3S1968-IQC50-A2LM3S1968-IQC50-A2 MCU Eval Kit
Stellaris LM3S1968-IQC50-A2LM3S1968-IQC50-A2
EKC-LM3S1968EKC-LM3S1968
TI
LM3S3748-IQC50-A0LM3S3748-IQC50-A0 MCU Eval Kit
Stellaris LM3S3748-IQC50-A0LM3S3748-IQC50-A0
EKC-LM3S3748EKC-LM3S3748
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
MCP9800/1/2/3
2-Wire High-Accuracy Temperature Sensor
332KB
MT45V512KW16PEGA-55WT
3.0V Core Async or Page PSRAM Memory
908KB
AAT3194
High Efficiency 1.5X Fractional Charge Pump For White LED Applications
316KB
ADS7843
168KB
AT91SAM3U Series
AT91 ARM Cortex-M3 based Microcontrollers SAM3U Series Preliminary
21.3MB
MIC29150
Series high-current low-dropout regulator
136KB
MMA7341L
±3g, ±11g Three Axis Low-g
172KB
MT29F2G08AABWP
NAND Flash Memory
1.03MB
MAX3232CDBRMAX3232CDBR
3-V TO 5.5-V Multi channel RS-232 Line Driver/receiver with +-15-kV ESD Protection
272KB
WM8731
WM8731 Portable Internet Audio CODEC with Headphone Driver
762KB
Application Notes
File Name
Size
AT91 Assembler Code Startup Sequence for C Code Applications Software
116KB
AT91 Assembler Code Startup Sequence for C Code Applications Software Based on the AT91SAM7S64 Evaluate
140KB
Using the Two-wire interface (TWI) in Master Mode on AT91SAM Microcontrollers
1.05MB
AT91SAM Internet Radio
425KB
Connecting an Atmel ARM-based Serial Synchronous Controller to an I2S-compatible Serial Bus
114KB
Interfacing a 4x4 Keyboard to an AT91 Microcontroller
898KB
Migrating to an AT91SAM9G20-based System from an AT91SAM9260-based System
190KB
Signal Integrity and AT91 Products(Basic Relationships IBIS Data and your PCB)
676KB
Audio and Video CODEC Licensing
184KB
Using the ECC Controller on AT91SAM9260 and AT91SAM7SE Microcontrollers
774KB
Using the Serial Peripheral Interface with AT91SAMxx Devices
149KB
Interrupt Generation Using the AT91 Timer and Counter
112KB
Hardware & Software
File Name
Size
AT91SAM_update_1.6_for_MDK_3.7
12.2MB
AT91SAM3U-EK Software Package for IAR 5.3, Keil and GNU
38MB
Install AT91-ISP v1.13
3.64MB
SAM3_BSDL
8KB
SAM3_IBIS
88KB
SAM3U-EK DevStart_v1.0.0
3.94MB
SAM3U-EK Hardware files
3.89MB
SAM-BA_CDC
6MB
  • ap:arm
  • sp:atmel
  • at:evaluation_kit
  • at:tech_first_kit
