Embedded and Microcontrollers
Documents Tech First Kit-Luminary Micro-EKI-LM3S811-ARM-EVK
  • Author Author: tech2
  • Date Created: 24 Nov 2009 6:08 AM Date Created
  • Last Updated Last Updated: 27 Oct 2013 2:26 AM
  • Views 1355 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The Stellaris LM3S811-IQN50-C2LM3S811-IQN50-C2 Evaluation Board is both a compact and versatile evaluation platform for the Stellaris LM3S811-IQN50-C2LM3S811-IQN50-C2 ARMRegistered CortexTm– M3 – based microcontroller, and an In-Circuit Debug Interface (ICDI) for any Stellaris microcontroller-based target board. This board allows users to evaluate, prototype, and create application-specific designs.
Kit Contents
The EKI-LM3S811..EKI-LM3S811.. Evaluation Kit contains the hardware essentials you will need to use the Kit. The items in the Evaluation Kit and their use are as follows.
  • LM3S811-IQN50-C2LM3S811-IQN50-C2 Evaluation Board (EVB)
  • USB cable
  • 20-pin JTAG/SWD target cable
  • Evaluation Kit CD containing:
    • IAR Systems Embedded Workbench
    • Set of sophisticated and easy-to-use development tools for embedded applications
    • Integrates the IAR C/C++ compiler, assembler, linker, librarian, text editor, project manager and C-SPY debugger in one integrated development environment (IDE)
    • 32 KB code-size limited KickStart version is included with device-, debug-, and download support for Stellaris microcontrollers
Key FeaturesBack to Top
  • Stellaris LM3S811-IQN50-C2LM3S811-IQN50-C2 microcontroller
  • OLED graphics display with 96 x 16 pixel resolution
  • Reset pushbutton and power indicator LED
  • Thumbwheel potentiometer for driving an Analog-to-Digital Converter (ADC) input
  • Standard ARMRegistered 20-pin JTAG debug connector for use as an In-Circuit Debug Interface (ICDI)
  • Schematics
  • I/O signal break-out pads for hardware prototyping
  • UART0 accessible through a USB Virtual COM Port (VCP)
  • USB interface for all communication and power
  • Evaluation copy of IAR Systems Embedded Workbench
Ordering InformationBack to Top
Supplier
Part Number
Luminary Micro
EKI-LM3S811EKI-LM3S811
Associated Products
Supplier
Description
Part Number
Luminary Micro
StellarisRegistered LM3S9B92 Microcontroller
FTDI
FT2232D Dual USB UART/FIFO I.C.
FT2232D/TRFT2232D/TR
TI
Cap-Free, NMOS, 400mA Low-Dropout Regulator with Reverse Current Protection
TPS73633DBVTG4TPS73633DBVTG4
TI
Low-Power DC/DC Boost Converter in SOT-23 and SON Packages
TPS61041DBVRTPS61041DBVR
Onsemi
1 kb Microwire Serial EEPROM
CAT93C46VI-GT3CAT93C46VI-GT3
Similar Products
SupplierDescriptionSupport DevicePart Number
Luminary Micro
EKC-LM3S811..EKC-LM3S811.. Ethernet Evaluation Kit for CodeSourcery G++
EKC-LM3S811EKC-LM3S811
Luminary Micro
EKT-LM3S811 Ethernet Evaluation Kit for Code Red Technologies Red Suite
EKT-LM3S811EKT-LM3S811
Luminary Micro
EKK-LM3S811..EKK-LM3S811.. Ethernet Evaluation Kit for KeilTm RealViewRegistered
EKK- LM3S811EKK- LM3S811
Luminary Micro
EKI-LM3S9B92..EKI-LM3S9B92.. Ethernet+USB-OTGEvaluation Kit
LM3S9B92
EKI-LM3S9B92EKI-LM3S9B92
Luminary Micro
EKK-LM3S9B90..EKK-LM3S9B90.. Ethernet+USB-OTG Evaluation Kit
LM3S9B90
EKI-LM3S9B90EKI-LM3S9B90
Luminary Micro
EKK-LM3S9B90..EKK-LM3S9B90.. Ethernet+USB-OTG Evaluation Kit for IAR Systems
LM3S9B90
Luminary Micro
DK-LM3S9B96 Development Kit
LM3S9B96
DK-LM3S9B96DK-LM3S9B96
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
StellarisRegistered LM3S811 Microcontroller
6.81MB
FT2232D
1.0MB
TPS73633
916KB
TPS61041
149KB
CAT93C46
149KB
Application Notes
File Name
Size
AN01237 Programming the On-Chip Flash Memory in a Stellaris Microcontroller
95KB
AN01240 Clocking Options for Stellaris Family Microcontrollers
107KB
AN01241 Using a Stellaris Microcontroller as an IO Processor
138KB
AN01242 Using the Stellaris Serial Flash Loader
118KB
AN01243 Adding 32 KB of Serial SRAM to a Stellaris Microcontroller
110KB
AN01248 Using the Stellaris Boot Loader
182KB
AN01249 Upgrading to Luminary Micro’s Stellaris Microcontrollers from Microchip’s PIC Microcontrollers
88KB
AN01250 Migrating to the New Members of the Stellaris Family of Microcontrollers
124KB
AN01257 Flash Protection for Stellaris Microcontrollers
191KB
AN01265 Optimizing Code Performance and Size for Stellaris Microcontrollers
95KB
AN01267 Using Stellaris Microcontrollers Internal Flash Memory to Emulate EEPROM
174KB
AN01270 Software UART for Stellaris Microcontrollers
119KB
AN01271 USB Certification for Stellaris Microcontroller-based USB Peripherals and Embedded Host Systems
87KB
Hardware & Software
File Name
Size
FreeRTOSV4.2.0_LM_IAR
330KB
Micrium-LuminaryMicro-uCOS-II-LM3S811
1.74MB
CMX-RTX evaluation
3.31MB
embos_cm3_iar_trial_v332f
1.87MB
Others Resources
File Name
Size
WP - The Future of the MCU Market
784KB
WP - An Introduction to the ARM Cortex-M3 Processor
346KB
WP - Motor Control Using a 32-bit Cortex-M3 MCU
493KB
WP - 32 BITS for a Buck
301KB
WP - Transitioning to Cortex-M3 based MCUs
476KB
WP - Moving_to_CortexM-3
514KB
Evaluation Kit Quickstart IAR Tools
328KB
README First for LM3S811 Evaluation Kit
138KB
ProductBrief_811_EvalKit
93KB
  • ap:arm
  • sp:luminary_micro
  • at:evaluation_kit
  • at:tech_first_kit
