Embedded and Microcontrollers
Documents Tech First Kit-Atmel-ATEVK1104-KIT-AVR32-EVK
  • Author Author: tech2
  • Date Created: 23 Nov 2009 12:43 PM Date Created
  • Last Updated Last Updated: 27 May 2012 12:57 AM
  • Views 1065 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The AVR32 EVK1104 is an evaluation kit for the AT32UC3A3256 which combines Atmel’s state of art AVR32 microcontroller with an unrivalled selection of communication interface like USB device including On-The-Go functionality, SDcard, NAND flash with ECC and stereo 16-bit DAC.
Kit Contents
The AVR32 EVK1104 contains the hardware and software essentials you will need to use it. The items in the EVK and their use are as follows.
  • AVR32 EVK1104
  • AVR32-SoftwareFramework-AT32UC3A3-0.7.0
Key FeaturesBack to Top
  • High Performance, Low Power AVRRegistered32 UC 32-Bit Microcontroller
  • Multi-Layer Bus System
  • Internal High-Speed Flash
  • Internal High-Speed SRAM
  • Interrupt Controller
  • Power and Clock Manager Including Internal RC Clock and One 32KHz Oscillator
  • Two Multipurpose Oscillators and Two Phase-Lock-Loop (PLL),
  • Watchdog Timer, Real-Time Clock Timer
  • External Memories
  • MultiMediaCard (MMC), Secure-Digital (SD), SDIO V1.1
  • CE-ATA, FastSD, SmartMedia, Compact Flash
  • Memory Stick: Standard Format V1.40, PRO Format V1.00, Micro
  • IDE Interface
  • One Advanced Encryption System (AES) for AT32UC3A3256S, AT32UC3A3128S and AT32UC3A364S
  • Universal Serial Bus (USB)
  • One 8-channel 10-bit Analog-To-Digital Converter, multiplexed with Digital IOs.
  • Two Three-Channel 16-bit Timer/Counter (TC)
  • Four Universal Synchronous/Asynchronous Receiver/Transmitters (USART)
  • Two Master/Slave Serial Peripheral Interfaces (SPI) with Chip Select Signals
  • One Synchronous Serial Protocol Controller
  • Two Master/Slave Two-Wire Interface (TWI), 400kbit/s I2C-compatible
  • On-Chip Debug System (JTAG interface)
  • 110 General Purpose Input/Output (GPIOs)
  • 144-pin TBGA and LQFP
  • Single 3.3V Power Supply
Ordering InformationBack to Top
Supplier
Part Number
Atmel
ATEVK1104ATEVK1104
Associated Products
Supplier
Description
Part Number
AtmelPSU for AVRONE
AVRONE-PSUAVRONE-PSU
AtmelDevelopment Kit, Debug Tool
ATJTAGICE2ATJTAGICE2
AtmelTest Board Kit, Combo
ATJTAGICE2 - JMS2206ATJTAGICE2 - JMS2206
AtmelMCU,32BIT,AVR32,256K FLASH, 144LQFP
AT32UC3A3256-ALUTAT32UC3A3256-ALUT
AtmelData Flash 64MB
AT45DB642D-TUAT45DB642D-TU
MicronSDRAM 256MB
MT48LC16M16A2P-75:DMT48LC16M16A2P-75:D
TIMultiplexer IC
TPS2112APWTPS2112APW
TITPS62040DRCR.TPS62040DRCR. - 1.2 A 1.25 MHZ, High Efficiency
TPS62040DRCRTPS62040DRCR
AtmelTouch sensor
QT60168-ASGQT60168-ASG
TIPower distribution switches
TPS2021DTPS2021D
TIAmplifier with I2C volume control
TPA6130A2RTJRTPA6130A2RTJR
AtmelMCU,32BIT,AVR32,256K FLASH,48TQFP
AT32UC3B1256-AUTAT32UC3B1256-AUT
Similar Products
SupplierDescriptionSupport DevicePart Number
Atmel
KIT, Evaluation for AVR32 AT32UC3A
AVR32 AT32UC3A
ATEVK1100ATEVK1100
Atmel
AVR32 AT32UC3A
ATEVK1105ATEVK1105
Atmel
ATSTK600 - Development Tools & Eval/Demo
AT32UC3B164, Tmega168, AT32UC3A0512
ATSTK600ATSTK600
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
AT32UC3A0512AVR32 32-Bit Microcontroller655.6KB
AT45DB642DAT45DB642D 64-megabit 2.7V Dual-interface DataFlash1.37MB
AVR32UCAVR32UC Technical Reference Manual1.18MB
MT48LC16M16A2MT48LC16M16A2 Synchronous Dram1.47MB
QProx QT60168QProx QT60168, QT60248 16,24 Key QMatrix IC867KB
TPS2112TPS2112Autoswitching Power Aux164KB
TPS62040DRCR.TPS62040DRCR.TPS62040DRC - 1.2 A 1.25 MHZ, High Efficiency372KB
TPA6130A2RTJR.TPA6130A2RTJR.138-mW Directpath stereo headphone amplifie with I2C volume control1.16MB
Application Notes
File Name
Size
AVR32 How to use the SSC in I2S mode116KB
AVR32 UC3A3 High Speed USB Design Guidelines88KB
AVR and AVR32 - Quick Reference Guide9.78MB
AVR JTAGICE mkII On-Chip Debug System348KB
AVR JTAGICE mkII Quick Start Guide100KB
Designing for Efficient Production with In-System Re-programmable Flash Microcontrollers228KB
How to Compile the standalone AVR32 Software Framework in AVR32 Studio V2302KB
JTAGICE mkII Communication Protocol0.98MB
UC3A3 Schematic Checklist284KB
Hardware & Software
File Name
Size
AVR32-SoftwareFramework-AT32UC3A3-0.7.028.6MB
EVK1104_Schematics_BOM400KB
  • ap:avr32
  • sp:atmel
  • at:evaluation_kit
  • at:tech_first_kit
