Embedded and Microcontrollers
Documents Tech First Kit-Atmel-ATEVK1105-KIT-AVR32-EVK
  • Author Author: tech2
  • Date Created: 24 Nov 2009 6:05 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:57 AM
  • Views 1066 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The AVR32 EVK1105 is an evaluation kit for the AT32UC3A3256 which combines Atmel’s state of art AVR32 microcontroller with an unrivalled selection of communication interface like USB device including On-The-Go functionality, SDcard, NAND flash with ECC and stereo 16-bit DAC.
The AVR32 EVK1105 is an evaluation kit for the AT32UC3A0512 which demonstrates Atmel’s state-of-the-art AVR32 microcontroller in Hi-Fi audio decoding and streaming applications.
Kit Contents
The kit contains reference hardware and software for generic MP3 player docking stations.
Key FeaturesBack to Top
  • High Performance, Low Power AVRRegistered32 UC 32-Bit Microcontroller
  • Multi-Layer Bus System
  • Internal High-Speed SRAM
  • Interrupt Controller
  • Power and Clock Manager Including Internal RC Clock and One 32KHz Oscillator
  • Two Multipurpose Oscillators and Two Phase-Lock-Loop (PLL),
  • Watchdog Timer, Real-Time Clock Timer
  • External Memories
  • MultiMediaCard (MMC), Secure-Digital (SD), SDIO V1.1
  • CE-ATA, FastSD, SmartMedia, Compact Flash
  • Memory Stick: Standard Format V1.40, PRO Format V1.00, Micro
  • IDE Interface
  • One Advanced Encryption System (AES) for AT32UC3A3256S, AT32UC3A3128S and AT32UC3A364S
  • Universal Serial Bus (USB)
  • One 8-channel 10-bit Analog-To-Digital Converter, multiplexed with Digital IOs.
  • Two Three-Channel 16-bit Timer/Counter (TC)
  • Four Universal Synchronous/Asynchronous Receiver/Transmitters (USART)
  • Two Master/Slave Serial Peripheral Interfaces (SPI) with Chip Select Signals
  • One Synchronous Serial Protocol Controller
  • Two Master/Slave Two-Wire Interface (TWI), 400kbit/s I2C-compatible
  • On-Chip Debug System (JTAG interface)
  • 110 General Purpose Input/Output (GPIOs)
  • 144-pin TBGA and LQFP
  • Single 3.3V Power Supply
Ordering InformationBack to Top
Supplier
Part Number
Atmel
ATEVK1105ATEVK1105
Associated Products
Supplier
Description
Part Number
Atmel
PSU for AVRONE
AVRONE-PSUAVRONE-PSU
Atmel
Development Kit, Debug Tool
ATJTAGICE2ATJTAGICE2
Atmel
Test Board Kit, Combo
ATJTAGICE2 - JMS2206ATJTAGICE2 - JMS2206
Atmel
MCU,32BIT,AVR32,256K FLASH, 144LQFP
AT32UC3A3256-ALUTAT32UC3A3256-ALUT
Atmel
Data Flash 64MB
AT45DB642D-TUAT45DB642D-TU
Micron
SDRAM 256MB
MT48LC16M16A2P-75:DMT48LC16M16A2P-75:D
TI
Multiplexer IC
TPS2112APWTPS2112APW
TI
Boot converter
TPS61020DRCRG4TPS61020DRCRG4
NS
Ethernet Transceiver
DP83848IVV/NOPBDP83848IVV/NOPB
TI
138-mW Directpath sterei headphone amplifer with I2C volume Control
TPA6130A2RTJRTPA6130A2RTJR
TI
Codec audio
TLV320AIC23BIPWTLV320AIC23BIPW
Atmel
Touch sensor
QT1081-ISGQT1081-ISG
Atmel
AT32UC3B1256-AUTAT32UC3B1256-AUT
TI
Power distribution switches
TPS2021DTPS2021D
Similar Products
SupplierDescriptionSupport DevicePart Number
Atmel
KIT, Evaluation for AVR32 AT32UC3A
AVR32, AT32UC3A
ATEVK1100ATEVK1100
Atmel
AVR32, AT32UC3A
ATEVK1104ATEVK1104
Atmel
ATSTK600 - Development Tools & Eval/Demo
AT32UC3B164, Tmega168, AT32UC3A0512
ATSTK600ATSTK600
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
AT32UC3A0512
AVR32 32-Bit Microcontroller
655.6KB
AT45DB642D
AT45DB642D 64-megabit 2.7V Dual-interface DataFlash
1.37MB
MT48LC16M16A2
MT48LC16M16A2 Synchronous Dram
1.5MB
TPS2112
TPS2112Autoswitching Power Aux
164KB
TPS61020DRCRG4
96% Efficient synchronous boot converter
548KB
10/100 Mb/s Ethernet Physical Layer Transceiver
3MB
TSM6866SDCARV
20V Dual N-Channel MOSFET
397KB
TPA6130A2RTJR.TPA6130A2RTJR.
1.16MB
TLV320AIC23BIPWRTLV320AIC23BIPWR
Stereo audio codec 8 to 96Khz with integrated headphone amplifier
232KB
QT1081
8-KEY Qtouch sensor IC
246KB
AT32UC3B1256-AUT
989KB
TPS2021D
378KB
Application Notes
File Name
Size
AVR32100Using the AVR32 USART
AVR32101onfiguring the AVR32 interrupt controller
AVR32102Using the AVR32 SDRAM controller
AVR32105Master and Slave SPI Driver
AVR32107Using TWI as a Master on the AVR32
AVR32108: Peripheral Direct Memory Access Driver
AVR32110: Using the AVR32 Timer/Counter
AVR32111: Using the AVR32 PIO Controller
AVR32113: Configuration and Use of the Memory Management Unit
AVR32114: Using the AVR32 LCD Controller
AVR32 UC3 USB DFU Bootloader
AVR32717: Compatibility Note AT32UC3Ax Revision E to Revision H or later
AVR32733: AVR32 UC3 Placing data and the heap in external SDRAM
AVR32758: AVR32 UC3 USB Host Mass Storage Bootloader
AVR32760: AVR32 UC3 USB DFU Bootloader Protocol
Hardware & Software
File Name
Size
Atmel QTouch Library 3.0
124MB
AVR QTouch Studio 2.0.1
8MB
AVR32 GNU Toolchain 2.2.1 - Windows
55MB
AVR32 GNU Toolchain 2.2.1 - Linux Ubuntu 9.04
31MB
AVR32 Studio 2.2 for Windows
266MB
AVR32 Studio 2.2 for Linux (x86_64)
250MB
AVR32 UC3B Software Framework 1.4.0
57MB
FLIP 3.3.4 for Windows
20MB
EVK1105 Schematics and BOM
  • ap:avr32
  • sp:atmel
  • at:evaluation_kit
  • at:tech_first_kit
