Embedded and Microcontrollers
Documents Tech First Kit-Atmel-EVK1040A-Touch Sensor Controller-EVK
  • Author Author: tech5
  • Date Created: 25 Nov 2009 7:07 AM Date Created
  • Last Updated Last Updated: 27 Oct 2013 5:24 AM
  • Views 1618 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The EVK1040A allows the user to evaluate all functions of the AT42QT1040 touch sensor controller. The kit provides a convenient reference design and allows the user to visualize discrete touch buttons and LEDs for per channel touch indication. There are movable jumpers on the board so that the Adjacent Key SuppressionRegistered (AKSRegistered) functionality and speed settings can be evaluated. The EVK1040A is battery powered and works stand-alone. Connections are included on the board which can be used to access debug data from the chip.
Kit Contents
The EVK1040A Evaluation Kit contains the hardware essentials you will need to use the Kit. The items in the Evaluation Kit and their use are as follows.
  • 1x EVK1040A Assembly
  • 1x CR2032 Battery, 3V, 235mAh
  • 2x Sample AT42QT1040-MMH ICs
  • 1x EVK1040A User Guide
Key FeaturesBack to Top
  • 4-channel touch sensor IC
  • 4 outputs for per-channel touch indication
  • Low operating voltage 1.8 to 5.5 V
  • Ultra-low power consumption
  • 2 response speed settings
  • AKS mode
  • Debug output provided to aid design
  • RoHS-compliant package
Ordering InformationBack to Top
Supplier
Part Number
Atmel
EVK1040AEVK1040A
Associated Products
Supplier
Description
Part Number
Atmel
Qtouch 4-key Sensor IC
AT42QT1040-MMUAT42QT1040-MMU
Similar Products
SupplierDescriptionSupport DevicePart Number
Atmel
EVK1060A Evaluation Board
AT42QT1060
EVK1060AEVK1060A
Atmel
EVK2160A Evaluation Board
AT42QT2160
EVK2160AEVK2160A
Freescale
Demo board for MPR031EPR2MPR031EPR2
MPR03X
DEMOMPR031DEMOMPR031
Freescale
KITMPR03XEVM Evaluation Kit
MPR03X
KITMPR03XEVMKITMPR03XEVM
Cypress
CapSense Express Evaluation Kit
CY8C20142
CY3218-CAPEXP3CY3218-CAPEXP3
Cypress
CapSense Express Development Kit
CY8C20142, CY8C201A0, CY8C20140 and more
CY3218-CAPEXP2CY3218-CAPEXP2
Microchip
PICDEM Touch Sense 1 Development Kit
PIC16F677-E/SSPIC16F677-E/SS, PIC16F887
DM164125DM164125
ST
STEVAL-IFP004V1Digital input termination PCLT2
PCLT2
STEVAL-IFP004V1STEVAL-IFP004V1
Silicon Labs
Capacitive Touch Sense Starter Kit
C8051F931
CAPTOUCHSENSESKCAPTOUCHSENSESK
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
AT42QT1040
Qtouch 4-key Sensor IC AT42QT1040
306KB
Application Notes
File Name
Size
ANKD01_QMatrix Panel Design Guidelines
427KB
ANKD02_Secrets of a Successful Qtouch Design
424KB
ANKD03_Using Philipp Springs to Create Touch Keys
205KB
QTAN0015_Power Supply Considerations for Atmel Capacitive-touch ICs
65KB
QTAN0016_Diagnostic Modes for Products with Atmel Capacitive-touch ICs
67KB
QTAN0017_Check the Effects of External Noise on Atmel Capacitive-touch ICs
273KB
QTAN0030_Implementing a Long Slide Control Using a QMatrix IC
721KB
QTAN0031_Avoiding False Touch Inputs Using Atmel Capacitive Touch Sense ICs
245KB
Others Resources
File Name
Size
Touch Sensors Design Guide
1.18MB
QMatrix Technology White Paper
388KB
  • sp:atmel
  • at:evaluation_kit
  • ap:capacitive_touch
