Embedded and Microcontrollers
Documents Tech First Kit-Luminary Micro-MDL-ACIM-Motor Control-RDK
  • Author Author: tech2
  • Date Created: 28 Dec 2009 9:39 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:55 AM
  • Views 869 views
  • Overview
  • Key Features
  • Ordering Information
Overview
The StellarisRegistered AC Induction Motor Reference Design Kit (ACIM RDK) contains all the necessary hardware and software for you to design, develop, and integrate your AC induction motor applications. The ACIM RDK combines the strength and flexibility of Stellaris microcontrollers with Fairchild Semiconductor's power modules to create an advanced variable speed AC motor control design that has been carefully engineered for performance, cost, and flexibility. AC induction motors are particularly suited for use in major home appliances (refrigerators, dishwashers, washing machines, and dryers), residential and light commercial HVAC systems, and three-phase industrial motor drives.
The Luminary Micro Stellaris Alternating Current Induction Motor Control Module (MDL-ACIM) is a rapid-time-to-market module solution that offers OEMs the capability of quickly adding AC induction motion control capability to any application. Combining the strength and flexibility of Luminary Micro's Stellaris microcontrollers with Fairchild Semiconductor's power modules creates an advanced ACIM motor control solution that has been carefully engineered for performance, cost, and flexibility. AC induction motors are particularly suited for use in major home appliances and white goods (refrigerators, dishwashers, washing machines, and dryers), residential and light commercial HVAC systems, and three-phase industrial motor drives.
Key Features
The ACIM RDK includes the following product features:
  • Advanced motor control for three-phase and single-phase AC induction motors
  • Accelerated integration process through a flexible platform
  • Dynamic braking circuit
  • Active in-rush control circuit
  • Easily change line filter, bus capacitors, and JTAG interface
  • Includes code for main control algorithms including space-vector modulation and sine control
  • Accurate current sensing using split low-side current sensing
  • Several isolated control input options including:
    • Virtual COM port through integrated USB port
    • Windows GUI application for configuration, control, and monitoring
    • Logic-level serial port
    • Speed potentiometer and mode switch
    • Speed and position monitoring using quadrature encoder/tachometer input
  • Electrically isolated JTAG port for software debugging
  • Bootloader for firmware upgrades over serial port
Ordering InformationBack to Top
Supplier
Part Number
Luminary Micro
MDL-ACIMMDL-ACIM
Associated Products
Supplier
Description
Part Number
Luminary Micro
Stellaris  LM3S818-IQN50-C2LM3S818-IQN50-C2 Microcontroller Industrial Temperature 48-pin LQFP
LM3S818-IQN50LM3S818-IQN50
Smart Power Module
FSBS10CH60FSBS10CH60
Similar Products
SupplierDescriptionSupport DevicePart Number
Luminary Micro
RDK-ACIMRDK-ACIM
Luminary Micro
AC induction motor control board, volume packaging
MDL-ACIM-BMDL-ACIM-B
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
MDL-ACIM
ACIM Board Data Sheet
212KB
LM3S818 Microcontroller Data Sheet
572MB
FSBS10CH60
10A, Smart Power Module
576KB
Application Notes
File Name
Size
Programming the On-Chip Flash Memory in a Stellaris Microcontroller
94.6KB
Clocking options for Stellaris Family Microcontrollers
106KB
Using a Stellaris Microcontroller as an I/O Processor
137KB
Using the Stellaris Serial Flash Loader
117KB
Adding 32KB of Serial SRAM to a Stellaris Microcontroller
109KB
Using the Stellaris Microcontroller Analog-to-Digital Converter
181KB
Upgrading to Luminary Micro's Stellaris Microcontrollers from Microchip's PIC Microcontrollers
123KB
Implementing RS-232 Flow Control on a StellarisRegistered Microcontroller
86.0KB
Using Schematic Part Libraries and PCB Footprint Libraries for StellarisRegistered Microcontrollers
190KB
Flash Protection for StellarisRegistered Microcontrollers
94.6KB
Optimizing Code Performance and Size for Stellaris Microcontrollers
173KB
Using Stellaris Microcontrollers Internal Memory to Emulate EEPROM
91.4KB
Software UART for StellarisRegistered Microcontrollers
118KB
Using the IEC 60730 Standard for Safe and Reliable Operation of StellarisRegistered Microcontrollers
86.5KB
AN-9035: Smart Power Module Motion-SPM in Mini-DIP User's Guide
1697KB
  • at:reference_design_kit
  • ap:motor_control
  • sp:luminary_micro
  • at:tech_first_kit
