Embedded and Microcontrollers
Documents Tech First Kit-Renesas-R0K571242S001BE-EVK
  • Author Author: tech2
  • Date Created: 4 Jan 2010 6:53 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 721 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The Renesas Starter Kit for SH7124 is intended as a user-friendly introductory and evaluation tool for the SH7124 microcontroller. The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E10A emulator.
The Renesas Starter Kit for SH7124 may be connected to the host PC using a simple RS232 serial connection (not normally fitted) or via the included USB E10A on chip debugging interface.
The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools.
Kit Contents
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E10A-USB for Starter Kit
  • Connection Cable (USB Cable, User Interface Cable)
  • Multi region 5V power supply
  • Quick Start Guide
  • CD-ROM
    • Documents : User Manual, Tutorial, and more
    • IDE : High-performance Embedded Workshop
    • C/C++ Compiler : C/C++ Compiler Package for SuperH Family Evaluation Version
    • Debugger : E10A-USB Emulator Debugger
Key FeaturesBack to Top
  • High-performance single-chip RISC with SH-2 core:
    • 65 MIPS 50 MHz
    • Built-in 32-bit multiplier
  • Built-in large capacity memory:
    • SH7125 (Flash 128KB/64KB, RAM 8KB)
    • SH7124 (Flash 128KB/64KB/32KB, RAM 8KB)
  • Various peripheral functions:
    • Powerful timer: MTU2 (16-bit x 6ch)
    • Compare match timer (16-bit x 2ch)
    • A/D converters: 10-bit, 8ch (4ch x 2unit)
    • Serial (SCI): 3ch
    • H-UDI: On-chip debugging functions
Ordering InformationBack to Top
Supplier
Part Number
RENESAS
R0K571242S001BER0K571242S001BE
Associated Products
Supplier
Description
Support Device
Part Number
ON SEMICONDUCTOR
Flip Flop Logic IC
74HC74
MC74HC74ADR2GMC74HC74ADR2G
MAXIM INTEGRATED PRODUCTS
Transceiver IC
Transceiver
MAX3222CUP+MAX3222CUP+
SCHURTER
SWITCH, PCB, PUSH, IP40
Reset switch
1241.16021241.1602
BOURNS
TRIMMER, 10K
potentiometer
3386F-1-103TLF3386F-1-103TLF
TYCO ELECTRONICS / AMP
PLUG, D, 40-40UNC, 9WAY
connector
3-338168-23-338168-2
Similar Products
SupplierDescriptionSupport DevicePart Number
RENESAS
Starter Kit for SH7086
R5F70865AD80FPV
R0K570865S001BER0K570865S001BE
RENESAS
KIT, STARTER, SH7201
R5S72011B120FP
R0K572011S001BER0K572011S001BE
RENESAS
KIT, STARTER, SH7203
R5S72030W200FP
R0K572030S000BER0K572030S000BE
RENESAS
Starter Kit for SH7211
R5F72115D160FPV
R0K572115S001BER0K572115S001BE
SILICON LABORATORIES
DEVELOPMENT KIT, 16-BIT, 100TQFP
C8051F060, C8051F061, C8051F062 and more
C8051F060DKC8051F060DK
MICROCHIP
BOARD, DEV, 16BIT, NANOWATT XLP
DM240311DM240311
MICROCHIP
DEVELOPMENT BOARD KIT, 16-BIT, 28-PIN
PIC24
DM300027DM300027
FREESCALE SEMICONDUCTOR
16-BIT HCS12DT256 STUDENT LEARNING KIT
HCS12DT256
APS12DT256SLKAPS12DT256SLK
Evaluation Board for the 16-bit MC9S12XE and XS-Families
MC9S12XEP100
EVB9S12XEP100EVB9S12XEP100
16-bit HCS12 DG128 Learning Kit
MC9S12DG128CFUERMC9S12DG128CFUER
LFEBS12UBLABLFEBS12UBLAB
Document ListBack to Top
Datasheet
Part Number
Description
Size
R5F70865AD80FPV
SH7125 Group SH7124 Group Hardware Manual
4419KB
RJJ99J0058-0100
[E10A version] Renesas Starter Kit for SH7124 CPU Board Schematics
70KB
REG10J0129-0100
[E10A version] Renesas Starter Kit for SH7124 Tutorial Manual
290KB
REG10J0128-0100
[E10A version] Renesas Starter Kit for SH7124 User's Manual
318KB
Application Notes
File Name
Size
Example of Using User Boot Mode of Renesas 0.18μm Flash Devices with Xmodem Data Transfer
135KB
Flash Memory Programming Routines
445KB
User Program Mode (UART) Function
176KB
Synchronous Serial Communication Unit Master Reception (Reading from EEPROM)
146KB
Synchronous Serial Communication Unit Master Transmission (Writing to EEPROM)
145KB
Serial EEPROM of HN58X25xxx Series Control Using Clock Synchronous SCI of Renesas SH
269KB
SH7000 Series 32 Bit × 32 Bit = 64 Bit (Signed) APPLICATION NOTE
169KB
SH7000 Series 32 Bit × 32 Bit = 64 Bit (Unsigned) APPLICATION NOTE
160KB
SH7000 Series Affine Transform APPLICATION NOTE
163KB
Using the DTC to Drive Clock Synchronous Data Transfer by the SCIF Mode
208KB
x16-Bit SDRAM Interface
549KB
A/D Conversion in Continuous Scan Mode
118KB
A/D Conversion in Single Mode
100KB
SH7080/SH7146/SH7125/SH7200 Series Application Note Activating the A/D Converter Using Compare-Match on MTU2 Channel 0
194KB
Utility To Convert S-Record Data To A C-Structure
259KB
Perl Script to Convert S-Record Data to a C Structure
632KB
SH7080/SH7146/SH7125/SH7200 Series Application Note Delayed Activation of A/D Converter Using MTU2
215KB
SH7080/SH7146/SH7125/SH7200 Series Application Note Skipping the Activation of A/D Converter Using MTU2
218KB
Clearing the MTU2S Counter by Using a Flag Setting Source of the MTU2
198KB
External Pulse Width Measurement Using Channel 5 of the MTU2
239KB
SH7080/SH7146/SH7125/SH7200 Series Application Note Three-Phase Complementary PWM Output
211KB
SCIF Asynchronous Serial Data Reception Function
528KB
SCIF Asynchronous Serial Data Transfer Function Using the DTC
611KB
I2C2 Single-Master Transmission (Writing to I2C-Bus EEPROM)
225KB
Hardware & Software
File Name
Size
SH7124 Renesas Starter Kit Sample Code
47KB
SH Compiler Application Note 4-Reference: Data of Library
313KB
Compiler Package Application Note Call Walker
335KB
SH Compiler Application Note 2-Compiler use guide: Object uniting function use guide
318KB
SH Compiler Application Note 2-Compiler use guide: Object usage guide
391KB
SH Compiler Application Note 3-IDE use guide: Simulator Usage Guide
838KB
SuperH C/C++ Compiler Package Application Note
5819KB
HI Series RTOS Application Note
3079KB
  • sp:renesas
  • at:evaluation_kit
  • at:tech_first_kit
