Embedded and Microcontrollers
Documents Tech First Kit-Luminary Micro-MDL-BDC-Motor Control-RDK
  • Author Author: tech2
  • Date Created: 29 Dec 2009 3:43 AM Date Created
  • Last Updated Last Updated: 6 Apr 2010 6:55 AM
  • Views 616 views
  • Overview
  • Key Features
  • Ordering Information
Overview
The StellarisRegistered Brushed DC Motor Control Module with CAN (MDL-BDC) offers a variable speed control for 12 V brushed DC motors at up to 40 A continuous current. The motor control module includes high performance Controller Area Network (CAN) connectivity and a rich set of control options and sensor interfaces, including analog and quadrature encoder interfaces. The high-frequency PWM on the MDL-BDC enables DC motors to run smoothly and quietly over a wide speed range. The module uses highly optimized software and a powerful 32-bit StellarisRegistered microcontroller to implement open-loop speed control as well as closed-loop control of speed, position, or motor current.
The StellarisRegistered MDL-BDC is powered by the LM3S2616 microcontroller, featuring CAN and advanced motion control capabilities. The LM3S2616 microcontroller's robust combination of features, along with the efficient and deterministic performance of the ARMRegistered CortexTm-M3 core, positions the modules into a wide variety of consumer and industrial applications, including factory automation devices and systems, mobile robots, household appliances, pumping and ventilation systems, and electric wheelchairs and mobility devices.
Key Features
The MDL-BDC ships as a ready-to-run, yet customizable, module with the following features:
  • Quiet control of brushed DC motors
    • 15 kHz PWM frequency
  • Two options for Speed control
    • Industry-standard R-C servo type (PWM) interface
    • Controller Area Network (CAN) interface
  • CAN communication
    • Full configurability of module options
    • Real-time monitoring of current, voltage, speed, and other parameters
    • Load firmware over CAN
  • Limit switch inputs for forward and reverse directions
  • Status LED indicates Run, Direction, and Fault conditions Motor brake/coast selector
  • Quadrature encoder input (QEI) and analog input
  • Color-coded screw terminals for all power wiring
  • Easy to customize using tools supporting the MDL-BDC from Keil, IAR, Code Sourcery, or Code Red (using a Stellaris evaluation kit or preferred ARMRegistered CortexTm-M3 debugger)
Ordering InformationBack to Top
Supplier
Part Number
Luminary Micro
MDL-BDCMDL-BDC
Associated Products
Supplier
Description
Part Number
Luminary Micro
Stellaris  LM3S2616 Microcontroller Industrial Temperature 64-pin LQFP
LM3S2616-IQR50-A0LM3S2616-IQR50-A0
XP Power
15V power plug In power adapter
VEH60US15VEH60US15
Similar Products
SupplierDescriptionSupport DevicePart Number
Luminary Micro
StellarisRegistered Brushed DC Motor Control Module with CAN for Volume Packaging
LM3S2616
MDL-BDC-BMDL-BDC-B
Luminary Micro
StellarisRegistered Brushed DC Motor Control Reference Design Kit (includes the MDL-BDC module)
LM3S2616
RDK-BDCRDK-BDC
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
MDL-BDC
Datasheet for Brushed DC Motor Control Module
577KB
LM3S2616
LM3S2616 Microcontroller Datasheet
6.55MB
Application Notes
File Name
Size
Programming the On-Chip Flash Memory in a Stellaris Microcontroller
94.6KB
ADC Oversampling Techniques
188KB
Clocking options for Stellaris Family Microcontrollers
106KB
Using a Stellaris Microcontroller as an I/O Processor
137KB
Using the Stellaris Serial Flash Loader
117KB
Adding 32KB of Serial SRAM to a Stellaris Microcontroller
109KB
Using the Stellaris Microcontroller Analog-to-Digital Converter
181KB
Upgrading to Luminary Micro's Stellaris Microcontrollers from Microchip's PIC Microcontrollers
123KB
Implementing RS-232 Flow Control on a StellarisRegistered Microcontroller
86.0KB
Using Schematic Part Libraries and PCB Footprint Libraries for StellarisRegistered Microcontrollers
190KB
Flash Protection for StellarisRegistered Microcontrollers
94.6KB
Optimizing Code Performance and Size for Stellaris Microcontrollers
173KB
Using Stellaris Microcontrollers Internal Memory to Emulate EEPROM
91.4KB
Software UART for StellarisRegistered Microcontrollers
118KB
Using the IEC 60730 Standard for Safe and Reliable Operation of StellarisRegistered Microcontrollers
86.5KB
Hardware & Software
File Name
Size
BDC RDK Quickstart
404KB
Brushed DC Motor Module and RDK Design Package Rev B
556KB
RDK-BDC Firmware Development Package
8.46MB
RDK-BDC Kit CD
62.1MB
  • at:reference_design_kit
  • ap:motor_control
  • sp:luminary_micro
  • at:tech_first_kit
