Embedded and Microcontrollers
Documents Tech First Kit-Ramtron-VersaKit-20xx-EVK
  • Author Author: tech2
  • Date Created: 6 Jan 2010 4:47 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 776 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The VRS51L2070 is a high performance, 8051-based microcontroller coupled with a fully-integrated array of peripherals for addressing a broad range of embedded design applications.
Based on a powerful 40-MIPS, single-cycle, 8051 microprocessor, the VRS51L2070’s memory sub-system includes, 64KB of Flash and 4352 bytes of SRAM. Support peripherals include a hardware based arithmetic unit capable of performing complex mathematical operations, USB-JTAG interface for Flash programming and non-intrusive In-Circuit Debugging/Emulation, internal oscillator, and a watchdog timer.
Communication and control of external devices is facilitated via an assortment of digital peripherals which include an enhanced fully configurable SPI bus, I2C interface, dual UARTs with dedicated baud rate generators, eight PWM controllers, three 16-bit timers, and two pulse width counter modules.
The VRS51L2070 is powered by a 3.3 volt supply, can function over the industrial temperature range, and is available in the MLF-68 or QFP-64 package.
Kit Contents
  • Development board that supports the VRS51L3074
  • VJTAG-USB programming/debugging interface
  • USB cable
  • 6V power supply (Euro or U.S. compatible)
Key FeaturesBack to Top
  • 8051 High Performance Single Cycle Processor (Operation up to 40 MIPS)
  • 64KB Flash (program memory, In-System/ln-Application Programmable)
  • 4KB + 256 Bytes of SRAM (4K Bytes - program or data memory)
  • USB-JTAG Interface for Flash Programming and Non-Intrusive Debugging/In-Circuit Emulation
  • MULT/DIV/ACCU Unit including Barrel Shifter
  • 56 General Purpose I/Os
  • 2 Serial UARTs/2 Baud Rate Generators (16-bit)
  • Enhanced SPI Interface (fully configurable word size)
  • Fully configurable I2C Interface (Master/Slave)
  • 16 External Interrupt Pins/Interrupt On Port Pin Change
  • 16-bit General Purpose Timer/Counters
  • 3 Timer Capture Inputs
  • 2 Pulse Width Counter Modules
  • 8 PWM Controller Outputs with Individual Timers
  • PWMs can be used as General Purpose Timers
  • Internal Oscillator
  • Dynamic System Clock Frequency Adjustment
  • Power Saving Features
  • Power-On Reset/Brown-Out Detect
  • Watchdog Timer
Ordering InformationBack to Top
Supplier
Part Number
RAMTRON
VERSAKIT-20XXVERSAKIT-20XX
Associated Products
Supplier
Description
Support Device
Part Number
RAMTRON
8-Bit Microcontroller IC
VRS51L2070
VRS51L2070-40-QGVRS51L2070-40-QG
TEXAS INSTRUMENTS
DRIVER/ RECEIVER, RS232, 3~5.5V
MAX3232
MAX3232CDRMAX3232CDR
RAMTRON
FRAM SERIAL I2C 3V 64K, SMD, 24CL64
24CL64
FM24CL64-GFM24CL64-G
SWITCHCRAFT
DC Power Jack
JACK SOCKET, DC
RAPC712XRAPC712X
RAMTRON
VOLTAGE DETECTOR, MICRO, SUP
Microprocessor Supervisor
FM31256-GFM31256-G
TEXAS INSTRUMENTS
V REG LDO 0.25A 3.3V
Voltage Regulator
REG102GA-3.3REG102GA-3.3
NATIONAL SEMICONDUCTOR
V REG LDO 0.4A +3.3V, SMD, 2937
Voltage Regulator
LM2937IMP-3.3LM2937IMP-3.3
TYCO ELECTRONICS / AMP
PLUG, D, 40-40UNC, 9WAY
connector
3-338168-23-338168-2
Similar Products
SupplierDescriptionSupport DevicePart Number
RAMTRON
KIT, DEVELOPMENT, VRS51L3XXX
VRS51L3074
VERSAKIT-30XXVERSAKIT-30XX
RAMTRON
INTERFACE, JTAG, USB
VERSAKIT-20XX/ VERSAKIT-30XXVERSAKIT-30XX
VERSA JTAG USBVERSA JTAG USB
SILICON LABORATORIES
DEVELOPMENT KIT, 8-BIT, 48TQFP
C8051F220, C8051F221, C8051F226
C8051F226DKC8051F226DK
DEVELOPMENT KIT
C8051F300, C8051F301, C8051F302
C8051F300DKC8051F300DK
DEVELOPMENT KIT, USB, 32LQFP
C8051F320, C8051F321
C8051F320DKC8051F320DK
ATMEL
DEVELOPMENT KIT, FLASH, MCU, 8051
AT89C51RE2, AT89C51RB2, AT89C51RC2
AT89STK-11AT89STK-11
Document ListBack to Top
Datasheet
Part Number
Description
Size
VRS51L2070
VRS51L2070
1.50MB
VersaKit-30xx User Guide
7.9MB
Include Files and SFR Mappings
VRS51L2070 Include Files
26KB
How to Use Versa Include Files
88KB
Application Notes
File Name
Size
AN502 - How to Run a 5V Character LCD Interface with a VRS51L2070
140KB
AN100 - Replacing SRAM with F-RAM
45KB
AN101 - A Single Memory for Code & Data Ruminations on design & applications
47KB
AN103 - 32 pin TSOP Pinouts
53KB
AN106 – Migrating from the FM20L08 to FM28V100
22KB
AN201 - Interrupting a 2-Wire Read
43KB
AN202 - Microchip MCU to 2-Wire F-RAM
63KB
AN203 - Dual Footprint for the FM24C256
72KB
AN300 - SPI F-RAM SPI Bus Compatibility Note
64KB
AN302 - F-RAM SPI Reads & Writes and Data Protection During Power Cycles
81KB
AN304 - Guide to SPI F-RAM
94KB
AN400 - Generating a Power-Fail Interrupt
42KB
AN401 - Capacitor Backup
23KB
AN403 - RTC Crystals - 6pF vs 12pF
80KB
AN404 - RTC Backup & UL Compliance
35KB
AN500 - System Design Notes for the VRS51L2070
501KB
AN501 - VRS51L2070/3074: Benefits of an Arithmetic Unit in FIR Filtering
84KB
AN402 - RTC Oscillator Guide
34KB
Hardware & Software
File Name
Size
Versa Ware JTAG Software v3.11
3.6MB
VRS51L2070/3074 Demonstration Programs
1.9MB
VRS51L3074 Demonstration Programs
313KB
RKit v.6.1 Development Suite
25MB
Configuring RIDE Compiler
358KB
Configuring uVision3 Compiler
358KB
  • sp:ramtron
  • at:evaluation_kit
  • at:tech_first_kit
