Embedded and Microcontrollers
Documents Tech First Kit-Renesas-R0K572030S000BE-EVK
  • Author Author: tech5
  • Date Created: 7 Jan 2010 6:17 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 2743 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The SH7203 is a high-performance microcontroller, incorporating an SH2A-FPU core. This LSI operates at a maximum operating frequency of 200MHz. It incorporates FPU supporting single-precision and double-precision, and which enables high signal processing performance. This LSI incorporates a USB standard v2.0 High Speed (480 Mbps) specification Host and Function interface, and a display controller supporting liquid crystal panels up to WVGA size (800x480pixels). These features provide display system capability and enable low-cost configuration of a digital audio player that performs high-speed data transfer via connection of USB flash memory or a portable audio or similar USB device.
In addition, this LSI includes peripheral functions such as a CAN controller, a serial sound interface (SSI) for digital audio data input/output, a serial communication interface with a 16-stage FIFO, an I2C bus interface.
The Renesas Starter Kit+ for SH7203 has been developed speed up code development and reduce time to market. An Renesas Starter Kit+, as the name suggests, is a complete development kit for Renesas microcontrollers.
Kit Contents
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • USB Host & Function Connection
  • SMSC Ethernet Interface
  • Hitachi 2.2” QVGA TFT Display
  • E10A-USB for Starter Kit
  • Connection Cable (USB Cable, User Interface Cable)
  • 128MB USB FLASH Memory Stick
  • Ethernet cross-wired cable
  • Multi region 12V power supply
  • Quick Start Guide
  • CD-ROM
    • Documents: User Manual, Tutorial and more
    • IDE: High-performance Embedded Workshop
    • C/C++ Compiler: C/C++ Compiler Package for SuperH Family Evaluation Version
    • Debugger: E10A-USB Emulator Debugger
Key FeaturesBack to Top
  • Operating frequency
    • 200MHz
  • CPU performance
    • 480MIPS (200MHz)
  • Cache
    • 16KB (separate 8K instructions/8K data, 4-way set associative type)
  • Debug
    • H-UDI, AUD-II
  • Package
    • 240-pin QFP (32mmx32mm)(0.5mm pitch)
  • Other features
    • Incorporates high-performance CPU core with built-in FPU, and realizes system control and high-precision operation by a single chip
    • USB host/function and NAND Flash memory controller built-in
    • Incorporates peripheral functions such as Timer for motor control, A/D converter, and etc. suitable for industrial equipment
    • On-chip LCDC (display controller)
    • Provides software solutions for various middleware
      Ordering InformationBack to Top
      Supplier
      Part Number
      RENESAS
      R0K572030S000BER0K572030S000BE
      Associated Products
      Supplier
      Description
      Support Device
      Part Number
      TEXAS INSTRUMENTS
      Buffer/Driver Logic IC
      Non-Inverting Buffer
      SN74LVC16244ADGGRSN74LVC16244ADGGR
      NATIONAL SEMICONDUCTOR
      Voltage Regulator IC
      Voltage Regulator
      LM1117MPX-5.0/NOPBLM1117MPX-5.0/NOPB
      DC/DC Converter IC
      DC/DC Converter
      LM2575S-3.3/NOPBLM2575S-3.3/NOPB
      FAIRCHILD SEMICONDUCTOR
      V REG, LDO 1A 1.2V, SMD
      Voltage Regulator
      FAN1112SXFAN1112SX
      Voltage Regulator
      LM1117MPX-ADJ/NOPBLM1117MPX-ADJ/NOPB
      MAXIM INTEGRATED PRODUCTS
      Transceiver IC
      Transceiver
      MAX3222CUP+MAX3222CUP+
      MICREL
      Analog Switch / Multiplexer (Mux) IC
      Analog Switch
      MIC2026-2YMMIC2026-2YM
      SMSC
      Ethernet Controller
      10/100MbT Ethernet,QSPI,TDM,UART,USB
      LAN9118-MTLAN9118-MT
      BOURNS
      TRIMMER, 10K
      potentiometer
      3386F-1-103TLF3386F-1-103TLF
      TYCO ELECTRONICS / AMP
      PLUG, D, 40-40UNC, 9WAY
      connector
      3-338168-23-338168-2
      Similar Products
      SupplierDescriptionSupport DevicePart Number
      RENESAS
      Starter Kit for SH7124
      R5F71242D50FP
      R0K571242S001BER0K571242S001BE
      RENESAS
      KIT, STARTER, SH7201
      R5S72011B120FP
      R0K572011S001BER0K572011S001BE
      RENESAS
      Starter Kit for SH7086
      R5F70865AD80FPV
      R0K570865S001BER0K570865S001BE
      RENESAS
      Starter Kit for SH7211
      R5F72115D160FPV
      R0K572115S001BER0K572115S001BE
      SILICON LABORATORIES
      DEVELOPMENT KIT, 16-BIT, 100TQFP
      C8051F060, C8051F061, C8051F062 and more
      C8051F060DKC8051F060DK
      MICROCHIP
      BOARD, DEV, 16BIT, NANOWATT XLP
      DM240311DM240311
      MICROCHIP
      DEVELOPMENT BOARD KIT, 16-BIT, 28-PIN
      PIC24
      DM300027DM300027
      FREESCALE SEMICONDUCTOR
      16-BIT HCS12DT256 STUDENT LEARNING KIT
      HCS12DT256
      APS12DT256SLKAPS12DT256SLK
      Evaluation Board for the 16-bit MC9S12XE and XS-Families
      MC9S12XEP100
      EVB9S12XEP100EVB9S12XEP100
      16-bit HCS12 DG128 Learning Kit
      MC9S12DG128CFUERMC9S12DG128CFUER
      LFEBS12UBLABLFEBS12UBLAB
      Document ListBack to Top
      Datasheet
      Part Number
      Description
      Size
      R5S72030W200FP
      SH7203 Group Hardware Manual
      9733KB
      REG99J0014-0600
      Renesas Starter Kit+ for SH7203 CPU Board Schematics
      243KB
      REG10J0061-0200
      Renesas Starter Kit+ for SH7203 Tutorial Manual
      408KB
      REG10J0060-0200
      Renesas Starter Kit+ for SH7203 User's Manual
      600KB
      Application Notes
      File Name
      Size
      Example of Using User Boot Mode of Renesas 0.18μm Flash Devices with Xmodem Data Transfer
      135KB
      Flash Memory Programming Routines
      445KB
      User Program Mode (UART) Function
      176KB
      Synchronous Serial Communication Unit Master Reception (Reading from EEPROM)
      146KB
      Synchronous Serial Communication Unit Master Transmission (Writing to EEPROM)
      145KB
      Serial EEPROM of HN58X25xxx Series Control Using Clock Synchronous SCI of Renesas SH
      269KB
      SH7000 Series 32 Bit × 32 Bit = 64 Bit (Signed) APPLICATION NOTE
      169KB
      SH7000 Series 32 Bit × 32 Bit = 64 Bit (Unsigned) APPLICATION NOTE
      160KB
      SH7000 Series Affine Transform APPLICATION NOTE
      163KB
      Using the DTC to Drive Clock Synchronous Data Transfer by the SCIF Mode
      208KB
      x16-Bit SDRAM Interface
      549KB
      A/D Conversion in Continuous Scan Mode
      118KB
      A/D Conversion in Single Mode
      100KB
      SH7080/SH7146/SH7125/SH7200 Series Application Note Activating the A/D Converter Using Compare-Match on MTU2 Channel 0
      194KB
      Utility To Convert S-Record Data To A C-Structure
      259KB
      Perl Script to Convert S-Record Data to a C Structure
      632KB
      SH7080/SH7146/SH7125/SH7200 Series Application Note Delayed Activation of A/D Converter Using MTU2
      215KB
      SH7080/SH7146/SH7125/SH7200 Series Application Note Skipping the Activation of A/D Converter Using MTU2
      218KB
      Clearing the MTU2S Counter by Using a Flag Setting Source of the MTU2
      198KB
      External Pulse Width Measurement Using Channel 5 of the MTU2
      239KB
      SH7080/SH7146/SH7125/SH7200 Series Application Note Three-Phase Complementary PWM Output
      211KB
      SCIF Asynchronous Serial Data Reception Function
      528KB
      SCIF Asynchronous Serial Data Transfer Function Using the DTC
      611KB
      I2C2 Single-Master Transmission (Writing to I2C-Bus EEPROM)
      225KB
      Hardware & Software
      File Name
      Size
      SH7211 Renesas Starter Kit Sample Code
      47KB
      SH Compiler Application Note 4-Reference: Data of Library
      313KB
      Compiler Package Application Note Call Walker
      335KB
      SH Compiler Application Note 2-Compiler use guide: Object uniting function use guide
      318KB
      SH Compiler Application Note 2-Compiler use guide: Object usage guide
      391KB
      SH Compiler Application Note 3-IDE use guide: Simulator Usage Guide
      838KB
      SuperH C/C++ Compiler Package Application Note
      5819KB
      HI Series RTOS Application Note
      3079KB
    • sp:renesas
    • at:evaluation_kit
    • at:tech_first_kit
