Embedded and Microcontrollers
Documents Tech First Kit-NXP-OM11043-MCU-Prototyping Board
  • Author Author: tech2
  • Date Created: 7 Jan 2010 1:20 PM Date Created
  • Last Updated Last Updated: 27 Oct 2013 2:25 AM
  • Views 834 views
  • Overview
  • Key Features
  • Ordering Information
Overview
The mbed NXP LPC1768FBD100,551LPC1768FBD100,551 board lets you create prototypes without having to work with low-level microcontroller details, so you can experiment and iterate faster than ever. Designers compose and compile embedded software using a browser-based IDE, then download it quickly and easily, using a simple drag-and-drop function, to the board's NXP Cortex-M3 microcontroller LPC1768FBD100,551LPC1768FBD100,551.
Engineers new to embedded applications can use the board to prototype real products incorporating microcontrollers, while experienced engineers can use it to be more productive in early stages of development. The mbed tools are designed to let you try out new ideas quickly, in much the same way that an architect uses a pencil and paper to sketch out concepts before turning to an advanced CAD program to implement a design.
Key Features
  • Convenient form-factor: 40-pin DIP, 0.1-inch pitch
  • Drag-and-drop programming, with the board represented as a USB drive
  • Best-in-class Cortex-M3 hardware
    • 100 MHz ARM with 64 KB of SRAM, 512 KB of Flash
    • Ethernet, USB OTG
    • SPI, I2C, UART, CAN
    • GPIO, PWM, ADC, DAC
  • Easy-to-use online tools
    • Web-based C/C++ programming environment
    • Uses the ARM RealView compile engine
    • API-driven development using libraries with intuitive interfaces
    • Comprehensive help and online community
Ordering InformationBack to Top
Supplier
Part Number
NXP
OM11043OM11043
Associated Products
Supplier
Description
Part Number
NXP
ARM Cortex-M3 microcontroller with 128KB flash, 32KB SRAM, 10/100 ethernet, 2 CAN, 12-bit ADC
LPC1764FBD100LPC1764FBD100
NXP
ARM Cortex-M3 microcontroller with 256KB flash, 64KB SRAM, USB 2.0 Host/Device/OTG, 2 CAN, I2S, 12-bit ADC, 10-bit DAC
LPC1765FBD100LPC1765FBD100
NXP
ARM Cortex-M3 microcontroller with 256KB flash, 64KB SRAM, 10/100 ethernet, USB 2.0 Host/Device/OTG, 2 CAN, I2S, 12-bit ADC, 10-bit DAC
LPC1766FBD100LPC1766FBD100
NXP
ARM Cortex-M3 microcontroller with 512KB flash, 64KB SRAM, 10/100 ethernet, USB 2.0 Host/Device/OTG, 2 CAN, I2S, 12-bit ADC, 10-bit DAC
LPC1768FBD100LPC1768FBD100
Similar Products
SupplierDescriptionSupport DevicePart Number
NXP
Rapid prototyping for the LPC2368FBD100,551LPC2368FBD100,551 MCU
OM11042OM11042
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
LPC1768 Datasheet
946KB
Application Notes
File Name
Size
IEC 60601-1-8 audible alert generator using the LPC1700
649KB
LPC1700 Ethernet MII Management (MDIO) via software
256KB
LPC1700 RTC hardware auto calibration
337KB
LPC1700 secondary USB bootloader
771KB
LPC1700 timer triggered memory to GPIO data transfer
163KB
Migrating to the LPC1700 series
615KB
Porting uIP1.0 to LPC1700
365KB
Using Code Read Protection in LPC1700
241KB
Hardware & Software
File Name
Size
Errata sheet LPC1758
42.1KB
  • at:prototyping_board
  • sp:nxp
  • ap:mcu
  • at:tech_first_kit
