Embedded and Microcontrollers
Documents Tech First Kit-Olimex-LPC-2478STK-ARM-EVB
  • Author Author: tech2
  • Date Created: 8 Jan 2010 3:53 AM Date Created
  • Last Updated Last Updated: 27 Oct 2013 2:25 AM
  • Views 742 views
  • Overview
  • Key Features
  • Ordering Information
Overview
LPC-2478STK is a starter kit which uses MCU LPC2478 from NXP. This powerful MCU supports various serial interfaces such as USB host, USB device, UART, CAN, etc. In addition you will find also audio input and output as well as MP3 decoder, digital accelerometer, JTAG, Ethernet, touchscreen TFT display and SD/MMC card connector on this board. All this along with the ARM7TDMI-STm architecture and uC Linux allow you to build a diversity of powerful applications to be used in a wide range of situations This ENC28J60/MLENC28J60/ML-H board is the world smallest ENC28J60/MLENC28J60/ML Ethernet controller Development board.
Key Features
The LPC-2478STK has the following features:
  • MCU: LPC2478
  • LCD 3.5" 320x240 24bit color TFT color with backlight and touchscreen
  • MP3 decoder DSP + codec VS1002D
  • 3-axis digital accelerometer with 11 bit accuracy
  • 64MB SDRAM
  • USB host connector
  • USB device connector
  • IrDA transciever (optional)
  • MICTOR trace connector (optional)
  • PS2 keyboard connector
  • 100Mbit Ethernet
  • CAN driver and connector
  • RS232 with ICSP control
  • SD/MMC card connector
  • JTAG connector
  • (optional) MICTOR TRACE connector
  • Reset button and circuit
  • 2 buttons
  • 1 trimpot
  • UEXT connector
  • Audio IN
  • Audio OUT
  • RTC battery
  • FR-4, 1.5 mm, red soldermask, component print
  • Dimensions:134.6x101.6mm (5.3 x 4.0")
Ordering InformationBack to Top
Supplier
Part Number
Olimex
LPC-2478STKLPC-2478STK
Associated Products
Supplier
Description
Part Number
NXP
Single-chip 16-bit/32-bit MCU
LPC-2478LPC-2478
ON Semi
1.5 A, Step-Up/Down/ Inverting Switching Regulators
MC34063ADGMC34063ADG
Micrel
PHY Transceiver
KSZ8721BLKSZ8721BL
National Semi
Dual Port USB Power Switch and Over-Current Protection
LM3526M-H/NOPBLM3526M-H/NOPB
Sharp
TFT DISPLAY, 3.5
LQ035Q3DW02LQ035Q3DW02
Similar Products
SupplierDescriptionSupport DevicePart Number
Olimex
Development Board with 8MB SRAM, 4MB FLASH, CAN, RS232, Ethernet, SD/MMC
LPC2294
LPC-L2294LPC-L2294
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
LPC2478
425KB
MC34063ADG
1.38MB
KSZ8721BL
PHY Transceiver
766KB
LM3526M-H/NOPB.
749KB
LQ035Q3DW02
TFT DISPLAY, 3.5", LED BL
1.18MB
Application Notes
File Name
Size
AN10764 (LPC24xx USB bootloader)
305KB
Ethernet secondary ISP bootloader
769.2KB
Interfacing 4-wire and 5-wire resistive touchscreens to the LPC247x
139.1KB
LPC2000 secondary bootloader for code update using IAP
500.4KB
Migrating to the LPC1700 series
615.1KB
PCB layout guidelines for NXP MCUs in BGA packages
163.7KB
Porting uIP1.0 to LPC23xx/24xx
466.2KB
Using IAP for LPC2000 ARM devices
122.9KB
Using the LPC24xx EMC peripheral to drive SDRAM
196.6KB
Theory and Applications of the MC34063 and µA78S40 Switching Regulator Circuits
395KB
Application Note 694 A DMOS 3A, 55V, H-Bridge: The LMD18200
408KB
Hardware & Software
File Name
Size
LPC-2478STK schematic
315KB
uClinux-dist-lpc_2478_stk-fixA.patch.bz2 Fix for uClinux from the initial revion of the LPC-2478-STK CD
28.2KB
LPC2478-STK demo code for EW-ARM 5.20
434KB
  • ap:arm
  • sp:olimex
  • at:tech_first_kit
  • at:evaluation_kit_board
