Embedded and Microcontrollers
Documents Tech First Kit-OLIMEX-STM32-P103-MCU-Dev Kit
  • Author Author: tech5
  • Date Created: 8 Jan 2010 4:35 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 1518 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The ARM Cortex-M3 processor is the latest generation of ARM processors for embedded systems. It has been developed to provide a low-cost platform that meets the needs of MCU implementation, with a reduced pin count and low-power consumption, while delivering outstanding computational performance and an advanced system response to interrupts. The ARM Cortex-M3 32-bit RISC processor features exceptional code-efficiency, delivering the high-performance expected from an ARM core in the memory size usually associated with 8- and 16-bit devices.
The STM32F103 Performance Line family has an embedded ARM core and is therefore compatible with all ARM tools and software. It combines the high performance ARM Cortex-M3 CPU with an extensive range of peripheral functions and enhanced I/O capabilities. STM32-P103 is good start-up board for learning the new ST Cortex-M3 based microcontrollers STM32F103RBT6. It have RS232 and both USB and CAN , the prototype area with all microcontrollers port near it allow customer easy to implement his own schematics and add-ons.
Kit Contents
  • STM32-P103 HEADER BOARD
  • STM32F103RBT6 microcontroller
Key FeaturesBack to Top
  • MCU: STM32F103RBT6 ARM 32 bit CORTEX M3Tm with 128K Bytes Program Flash, 20K Bytes RAM, USB, CAN, x2 I2C, x2 ADC 12 bit, x3 UART, x2 SPI, x3 TIMERS, up to 72Mhz operation
  • Standard JTAG connector with ARM 2x10 pin layout for programming/debugging with ARM-JTAG
  • USB connector
  • CAN driver and connector
  • RS232 driver and connector
  • UEXT connector which allow different modules to be connected (as MOD-MP3, MOD-NRF24LR, etc)
  • SD-MMC connector
  • Backup battery connector
  • RESET button
  • Status LED
  • Power supply LED
  • On board voltage regulator 3.3V with up to 800mA current single power supply: takes power from USB port or power supply jack
  • 8 Mhz crystal oscillator
  • 32768 Hz crystal and RTC backup battery connector
  • Extension headers for all uC ports
  • PCB: FR-4, 1.5 mm (0,062"), soldermask, silkscreen component print
  • Dimensions: 100 x 90mm (3.94 x 3.5")
      Ordering InformationBack to Top
      Supplier
      Part Number
      OLIMEX
      STM32-P103STM32-P103
      Associated Products
      Supplier
      Description
      Part Number
      OLIMEX
      USB JTAG Debugger
      ARM-USB-OCDARM-USB-OCD
      OLIMEX
      JTAG Dongle Interface
      ARM-JTAG-EWARM-JTAG-EW
      ST Microelectronics
      32BIT MCU, CORTEX M3, 128K FLASH
      STM32F103RBT6STM32F103RBT6
      Similar Products
      SupplierDescriptionSupport DevicePart Number
      OLIMEX
      KIT, STARTER, ST ARM CORTEX-M3
      STM32F103RBT6
      STM32-103STKSTM32-103STK
      Document ListBack to Top
      Datasheet
      Part Number
      Description
      Size
      STM32-P103
      STM32-P103 users manual
      910KB
      Application Notes
      File Name
      Size
      Smartcard interface with the STM32F10x microcontrollers
      153KB
      EEPROM emulation in in STM32F10x microcontrollers
      122KB
      How to achieve 32-bit timer resolution using the link system in STM32F101xx and STM32F103xx microcontrollers
      71.3KB
      STM32F10xxx hardware development: getting started
      72.9KB
      STM32F10x in-application programming using the USART
      63.7KB
      Using the STM32F101xx and STM32F103xx DMA controller
      153KB
      EMC Design Guide for ST Microcontrollers
      122KB
      STM32-P103 schematic
      64KB
      JTAG connector (top view)
      63.7KB
      Blinking LED C source for EW-ARM 5.11
      153KB
      Sample mouse driver C source for EW-ARM 5.11
      122KB
      Mass Storage C source for EW-ARM 5.11
      71.3KB
      USB-to-RS232 Virual COM port C source for EW-ARM 5.11
      1.5MB
      Blinking LED project for GCC + Eclipse + OpenOCD
      153KB
      OpenOCD + Eclipse set of projects 1.00
      122KB
      910KB
      Hardware & Software
      File Name
      Size
      64KB
      63.7KB
      153KB
      122KB
      71.3KB
      1.5MB
      153KB
      122KB
      910KB
      Other Resources
      File Name
      Size
      The complete list of projects
      63.7KB
    • at:development_kit
    • ap:mcu
    • sp:olimex
    • at:tech_first_kit
